New owner... Nearly.. Leisure battery
Is it a neccisity with a conversion?
Hello Mark,
No, but if you want to run lights, fans, cool boxes, radios, TVs etc when stationary and be able to start the engine in the morning!
Where to put it can be a bit tricky.
They are not expensive to install.
So u need split relay and leisure battery for the job then
At its simplest. Yes.
You need to think very carefully about your conversion if DIY.
What will you use the vehicle for?
They are so versatile.
If getting a professional to do the work you can discuss it with them.
If you use campsites an EHU is very useful.
Thinking of a EHU 15 metre extension with rcd and usbs on it for sites
Sounds good.
I have a battery charger hooked up to the leisure battery, so if I am on EHU I am also charging my leisure battery.
15m should be long enough, I have 25m. 2.5mm. I have red some campsites are not happy with 1.5mm.
Other members will say they have never had any trouble with 1.5mm
I have read, on this Forum, that 15m can be too short at some camp sites !
