Ian S Posted August 28, 2022 Posted August 28, 2022 Dear all I would be very grateful for any advice. I would particularly like to hear from anyone who has had a similar problem and has solved it. My mechanic thinks that it is an automatic gearbox problem. This is a January 2008 2400cc hybrid petrol Alphard, which I have had for about 10 months. The problem started a month ago immediately after repairs to the rear suspension. The problem comes and goes and is most marked at higher speeds and when climbing. The engine ‘jerks’ under acceleration, misses beats and has reduced power (50 mph on motorway climbing). The error code: ‘P0171 System too lean A/F lean malfunction bank 1’ has come up twice. This states that the engine is running with a reduced fuel mixture, but my mechanic has looked at this twice and is convinced that this is just a symptom of a deeper problem. Actions taken so far: coil and plugs changed, gearbox oil changed and all pipework checked for air leaks. Any suggestions? My mechanic thinks that it is an automatic gearbox problem and that it will be expensive… Best wishes Ian
Bazzer1955 Posted August 28, 2022 Posted August 28, 2022 To me this sounds like a fuel problem as you say when the symptoms happen the engine is under load, acceleration, motorway etc. I am going to refer to my Octavia which had a loss of power, this was caused by a partially blocked fuel filter.................Just a thought
Picasso Posted August 28, 2022 Posted August 28, 2022 P0171 is front lamba sensor or maf sensor not gearbox it's a fuel air ratio problem I would personally change maf sensor first as I have had same problem with my 3.0 also chuck in a bottle of cat cleaner in the fuel and give it a good blast on the motorway I have been adding cat cleaner now once a month and not had any problems since . 1
Ian S Posted August 30, 2022 Author Posted August 30, 2022 Fantastic! I really appreciate the opportunity to get experienced advice on this forum. I will ask Alex (my mechanic) to do these things. Very best wishes Ian
Ian S Posted September 22, 2022 Author Posted September 22, 2022 Can I give an update on the Toyota Alphard? We replaced the MAF sensor (£160). All seemed well. I went to Halfords last Saturday and put catalytic cleaner into a 1/8th full tank. I drove 15 mins (as suggested) then stopped to fill up with V-Power unleaded petrol (mechanic said this would clean the engine). I drove on. 5 minutes later the engine cut-out. I had to have the car recovered (£200!) as it would not start. Since then it has been at home. If I start it, it runs normally for a few seconds or longer, then cuts out. Once it ran for two minutes. The engine sounds normal. I wondered if it is the computer which is cutting the engine because it is getting some sort of 'serious error' code? A few thoughts: Is the catalytic cleaner in the fuel line a problem, which will clear Can these cars use V-Power fuel? Any other suggestions? Regards Ian
Rojie Posted September 22, 2022 Posted September 22, 2022 1 hour ago, Ian S said: Can I give an update on the Toyota Alphard? We replaced the MAF sensor (£160). All seemed well. I went to Halfords last Saturday and put catalytic cleaner into a 1/8th full tank. I drove 15 mins (as suggested) then stopped to fill up with V-Power unleaded petrol (mechanic said this would clean the engine). I drove on. 5 minutes later the engine cut-out. I had to have the car recovered (£200!) as it would not start. Since then it has been at home. If I start it, it runs normally for a few seconds or longer, then cuts out. Once it ran for two minutes. The engine sounds normal. I wondered if it is the computer which is cutting the engine because it is getting some sort of 'serious error' code? A few thoughts: Is the catalytic cleaner in the fuel line a problem, which will clear Can these cars use V-Power fuel? Any other suggestions? Regards Ian , E Hi Ian Sorry to hear about your issues. Fuelling your van with Shell V Power (E5) should be fine. It's probably ethanol free ! I don't use it, but feel you will receive reassurance from members that do use it Is this the first time you have used the Shell fuel ?
Ian S Posted September 22, 2022 Author Posted September 22, 2022 Yes. It was just a suggestion from the mechanic that if I was using catalytic cleaner then using the 'super' unleaded might also be a good idea as it contains cleaning agents. I usually use the 'ordinary' Any other thoughts? Do I need a Toyota main dealer??
Rojie Posted September 22, 2022 Posted September 22, 2022 3 hours ago, Ian S said: Yes. It was just a suggestion from the mechanic that if I was using catalytic cleaner then using the 'super' unleaded might also be a good idea as it contains cleaning agents. I usually use the 'ordinary' Any other thoughts? Do I need a Toyota main dealer?? Hi, Ian, Honestly, I don't know what you need ! Finding a Toyota dealer to work on a grey import is no easy task ! I have full confidence in any advice that Picasso gives, otherwise I would not have called upon him for an opinion. I am not a mechanic but I fail to understand why your mechanic thought you convertors needed a clean. How many miles has your machine done ? I'll send you a PM of the dealer that I bought my Alphie from. I believe, there is a garage 'next door' that does his work; not far from you. Perhaps a phone call to them may be helpful. I expect Picasso will be back on this thread asap.
Picasso Posted September 22, 2022 Posted September 22, 2022 Is there any codes still coming up after you changed the maf sensor
Picasso Posted September 22, 2022 Posted September 22, 2022 On the 2.4 you have 2 lamba sensors what a lot of people don't know is the 1st one bank one is a fuel ratio sensor and rear one bank 2 is a oxygen sensor I still, believe you have a fuel ratio sensor fault which is why your alphard not running right it not getting the correct fuel and air mix .
Ian S Posted September 22, 2022 Author Posted September 22, 2022 The engine computer light is glowing. My mechanic is sending someone on Monday to read the codes at our house to see if we can find the issue and avoid another recovery to the garage.
Picasso Posted September 23, 2022 Posted September 23, 2022 When you changed the maf sensor did you reset the codes
Ian S Posted September 26, 2022 Author Posted September 26, 2022 The mechanic has just been round with the computer. The error code is: P1300 Igniter Circuit #1 Any advice gratefully received! Ian
Picasso Posted September 26, 2022 Posted September 26, 2022 Ignition coil pack you have 4 bank 1 is 1st coil pack in the line I would replace all 4 and whilst there change the spark plugs to iridium plugs if you want part no. Please give your vin number
Ian S Posted October 16, 2022 Author Posted October 16, 2022 Thanks again for the advice. I think that things are all sorted out now, so I wanted to give the outcome in case anyone else gets the same error code (P1300 Igniter Circuit #1). My mechanic did not believe that it could be the coil packs as he had put four new ones in last month. However he swapped the coil pack on cylinder one with the one on cylinder three and the error code moved to that cylinder, confirming that the coil pack was the problem. He changed the coil pack and everything has worked well over the last few days. So in summary there have been two error codes, one after the other: ‘P0171 System too lean A/F lean malfunction bank 1’ ‘P1300 Igniter Circuit #1’ The first code went away after changing a MAF sensor (airflow sensor) The second code went away after changing a coil pack. My mechanic still suspects that we haven’t really got to the root of the problem, however at least the vehicle does run now! Thanks again for all the suggestions, particularly to Rojie and Picasso. Best wishes Ian
Picasso Posted October 17, 2022 Posted October 17, 2022 Ian I'm glad you got it sorted we are here to help each other 1
Sorin Posted April 15, 2024 Posted April 15, 2024 @Picasso, hi! Can you please help me with the same error? More exactly do you have any schematics of where the sensors are, maf or lambda sensors?
Picasso Posted April 15, 2024 Posted April 15, 2024 can you please supply me a reg no. pm it me if you want
Sorin Posted April 15, 2024 Posted April 15, 2024 (edited) 15 minutes ago, Picasso said: can you please supply me a reg no. pm it me if you want LN12DLJ , a 2.4l petrol Edited April 15, 2024 by Sorin
Picasso Posted April 15, 2024 Posted April 15, 2024 (edited) ok maf sensor circled in red by air filter o,e no. 222040p010 picture atatched my advice only buy genuine toyota link to a good place to buy as i buy all my genuine parts from here uk toyota price over £200 from this link £88.18 all in https://partsouq.com/en/shop/shoppingCart/view Edited April 15, 2024 by Picasso spelling
Sorin Posted April 15, 2024 Posted April 15, 2024 12 minutes ago, Sorin said: LN12DLJ , a 2.4l petrol I think I found the problem, one hose was cracked! Also, is the yellowish liquid normal inside the vacuum pipes?
Sorin Posted April 15, 2024 Posted April 15, 2024 1 minute ago, Picasso said: ok maf sensor circled in red by air filter o,e no. 222040p010 picture atatched my advice only by genuine toyota link to a good place to buy as i buy all my genuine parts from here uk toyota price over £200 frome this link £88.18 all in https://partsouq.com/en/shop/shoppingCart/view Ok, so my hose is pnc 12261
Picasso Posted April 15, 2024 Posted April 15, 2024 yes that the air intake pipe thats your problem you got a bigger problem now the yellowish liquid is oil your engine has blow back which means oil is passing your piston rings and causing pressure in the rocker and the pressure is passing your valve stem seals this is down to bad maintenace not reguar oil changes your pistin rings are stuck sorry to say this is a full engine rebuild 1
Sorin Posted April 15, 2024 Posted April 15, 2024 33 minutes ago, Picasso said: yes that the air intake pipe thats your problem you got a bigger problem now the yellowish liquid is oil your engine has blow back which means oil is passing your piston rings and causing pressure in the rocker and the pressure is passing your valve stem seals this is down to bad maintenace not reguar oil changes your pistin rings are stuck sorry to say this is a full engine rebuild Thank you so much for your help!
Register a new accountSign in
