Does anyone know what the tracking is on  2004 Alphard 3 litre.Any help appreciated.
Also l have 205 tyres, have been told 215s will fir  any comments appreciated.
Hi Michael,
There appears to be some variation in the figures. I found the following figures for our 2007 Alphard, via the jltechno lookup:
http://www.jltechno.com/en/alignment-data-lookup/40016/Toyota.html
Alignment Data Lookup->Toyota->Alphard/Vellfire:H10 Series:MNH10W
Alignment Specs
Parameter
MIN spec
Standard spec
MAX spec
Front Total Toe
-0.17
0.17
FL Toe
-0.09
0.09
FR Toe
-0.09
0.09
FL Camber
-1.42
0.08
FR Camber
-1.42
0.08
Rear Total Toe
-0.25
0.25
RL Toe
-0.13
0.13
RR Toe
-0.13
0.13
RL Camber
-2
-1
RR Camber
-2
-1
Left Caster
1.67
3.17
Right Caster
1.67
3.17
Left SAI
N/A
N/A
Right SAI
0
0
Firstly, these are different from the figures listed on the webpage that Picasso offered, and it may be that the variation relates to Malaysian data. To complicate matters, our wheel alignment specialist found alternative figures for 2002-07 Alphard, after searching Japanese data. They're a more extensive set of figures, but for some values the tolerance range is narrower than the figures above:
Toyota->Alphard H10 Series:MNH10W
Wheel Alignment Specification
Parameter
Minimum
      Maximum
Front Total Toe
-0.10
+0.10
FL Toe
-0.05
+0.05
FR Toe
-0.05
+0.05
FL Camber
-1.25
+0.05
FR Camber
-1.25
+0.05
FL Caster
+1.40
+3.10
FR Caster
+1.40
+3.10
FL SAI
+10.05
+11.35
FR SAI
+10.05
+11.35
FL Included Angle
FR Included Angle
Front Cross Camber
+8.40
+8.40
-0.45
+11.40
+11.40
+0.45
Front Cross Caster
-0.45
+0.45
Rear Total Toe
-0.15
+0.15
RL Toe
-0.08
+0.08
RR Toe
-0.08
+0.08
RL Camber
-2.0
-1.0
RR Camber
-2.0
-1.0
So, we chose to go with the figures that had less tolerance, on the basis that we'd be conforming with both sets of figures.
Worth noting, w
hilst the rear values are quoted, there's no adjustment because the rear axle is fixed. However, it could prove a useful check to see if the alignment is correct for the whole vehicle (which we found ours wasn't,
due to a poorly assembled wheel bearing retainer - 2 of the 4 nuts were missing so the leading edge of the wheel was facing slightly outwards...)
  • 2 years later...
In despair. 2004 3L FWD Alphard, pulls badly to the left, (but also pulls to the right when driven on the 'wrong side' of the road).
My garage has 4 wheel alignment but unable to adjust to the figures available on the internet due to 'insufficient adjustment availabl', even after shifting the front subframe to try and get more adjustment leeway. Back suspension bushes done, steering rack bushes done, back axle found to be out of true, and replaced. Nothing works. Is there anyone out there that can fix this? The car is otherwise immaculate, so well p****d off...ALphard
Hello Derek,
I have read that with 4wd vehicles it is very important that all tyres are the same brand, size, and wear.
What are the state of yours ?
Mine does exactly the same thing. Front wheel drive. I have tried everything including rear bushes and complete replacement of shocks and springs. New matching tyres all round.
Had the tracking done 4 times over 1.5 years in different garages each time.
I now live with it, and don't really notice it until i think about it. That's the fix unfortunately.
Not under braking, just driving straight.
Edited by Catweazle
I had mine checked earlier this year as the rear tyres were showing wear on the insides (I think) but the garage (TyrePros in Stevenage Old Town) said they were all in spec.
I remember thinking at the time, when looking at the structure underneath, how on earth any of it could be adjusted in any case, as it all looked to be solidly attached together.
The diagram their their alignment checker produced helped to explain it all.
