Has anyone had this issue and were able to resolve it?
I have a 2003 Alphard hybrid where the electric (Wheel) drive motors are not operating. The battery health monitor on the display shows that the battery is usually at 3 bars and remains green. Incidentally, I have recently replaced the 12 volt battery with a non-oem battery. I am getting the VSC warning light and the drive ready light is also red with the exclamation mark. The vehicle runs off of the ICE fine. My mechanic couldn’t scan the proper fault code so that he could “Speak” to the high voltage battery. Any wisdom on where to go next would be much appreciated.
Cheers, Monty
Cheers, Monty
Hello Monty,
Welcome to the Forum
Thank you Roger, its great to join a group of Alphard enthusiasts such as myself. I’m looking forward to contributing where I can.
Kind regards, and happy holidays !
Monty
Cheers, Monty
You need to go to a hybrid specialist such as the ones in the link, others are available if you do a google search,  https://www.hybridrepairservice.co.uk
It could be the inverter water pump from the lights displayed .
very easy to check
FROM COLD start the engine and remove the radiator cap from the small radiator located on the right as you look under the bonnet.
the fluid level should be showing signs of movement (up and down) if not pump not running
there is a video on utube which demonstrates this
Thanks ever so much Martin. I’ll give the procedure that you’ve suggested a go. At the very least, it will eliminate the inverter water pump as a possible cause of the issue.
Lind regards, Monty
