Alphard 2.4 automatic stalling and loss of speed up hills
Hi my first time on the site I have had the car for 3 years no real problems lpg conversation as soon as I bought it but recently the car will stall normally at the first junction I hit on my way to work 400 yards  it may be okay at the next 3/4 mile but I may stall again sometimes after driving 10 miles on a motorway all fine will stall again at next junction other times will do the journey fine no problems. On hills very slow on cold start as in 5 miles an hour when warm 20% less power on hills will normally always perform okay on flat motorways.I have had 2  garages look at the e c u is a problem to read as it's an import one said the code was a new air mass sensor needed bought one had it fitted no difference other one could not read it had it serviced and had the 4 plugs removed to check the piston power all 4 were 100% so not sure where to go  from here also the car's power steering locks when it stalls and brakes are not so good so can be worrying any ideas many thanks
Hi many thanks for your help it is nearly time for its service but will also look at the clogging I had a new maf fitted but alas made no difference but again many thanks David
I have it booked in tomorrow for just that fingers crossed ....
