Just noticed the plastic lens covering the led lights in the door mirror is missing. Have tried everywhere to get replacement  light unit or cover, but no luck.  Anybody got any ideas where to get one?
Thanks for the reply MonsterS.  Looks like the led lights I have got are an aftermarket item (no part numbers or name),  eventually I have found some on ebay, not quite the same size but slightly bigger, will have to modify the outer mirror case to fit, hopefully will go ok.
Have the same problem advise on mot can I ask what replacement you used thanks
It passed mot just wanted to no the source of your replacements cheers
