I have a Toyota Alphard 2006 3l V6 and when I use the lane assist function alongside my cruise control it doesn’t do anything?
I have tried it with and without cruise control
it is an import from japan
anyone know a fix/reset
Lane control is a button in the bottom left of the drivers side next to the steering wheel? Press it. Then when you are going over 40mph it comes on. If not check fuse box on lower left passenger footwell.
Hi I’ve located the fuse box... it is really tight down there and I don’t know which is for lane assist .i checked the diagram but doesn’t say. anyone know as it’s really really hard to pull out all fuses to check
I really appreciate you helping me many thanks.. I’ve had look through the diagram layout but if you look none actually relate to lane assist..
which one is it ?
