Toyota Alphard Velfire 2010 gear Box Issue
Toyota Alphard  Velfire 2010 2.4L
Bought June 2022. 58000 miles
Recently i have been hearing a noise coming from my gearbox. Its at its loudest at 20 miles per hour.
It is a 7 speed K112/F Super CVT-I Automatic 2.4 L
Has anyone had the same issues. Dont know where to start. thanks Martin
Hi, Have you checked the gear box oil level?
Thank you for your reply Paul. No I haven't. Is there an issue with gear boxes in a Velfire using oil that I don't know about. I will check and let you know ow I get on thanks
Hi. We finally got round to draining oil and removing sump (there was just over 5 ltrs of oil ) and dropped the sump. The sump was full of metal as per attached photos. The 2 biggest bits of metal are shown against a lighter for scale.
Assuming something is seriously wrong with the gear box. Any advice would be appreciated.
Those little metal cylinders in your sump are evidence of a roller bearing failure - sorry. It’s very likely that bits of hardened steel escaping a bearing will have done further damage elsewhere. Did you also drop the strainer? A full inspection and rebuild likely more expensive than sourcing a replacement (used, possibly refurbished) gearbox.
Edited by anotherdom
Yes I did remove the stainer. Going to source another gearbox. Thanks for your reply.
