Central locking failure
Hi I have a 2003 toyota alphard 3.0v
my key remotely locks the van and it beeps
my key does not remotely unlock the van and there is no beep
i have to turn the key in the lock to unlock and get into the van
as a result of this none of the doors unlock automatically and have to be manually opened by moving the lever below handle
the central locking button on the drivers door does not appear to work either
i thought it was the key and replace the battery but doesnt make any difference
i got the key tested by an auto electrical company who said the signal was weak and sporadic and not working properly
so im confused and dont know if its a bad key signal on both keys or central locking electrics inside the car
i dont have  technical manual so i cant check anything myself
any gomments or help is much appreciated
thanks for reply your correct it was the key and the problem is that the key battery keeps jumping out of the holder and was not fixed securely
i am now trying to figure out a way to hold the battery into the clip.......ive tried sellotaping it in but it still jumps out before i can get the case lid on ????
any help and advice apprecated how to hold battery inplace
