Newly bought alphard not starting
Hi i am actually here on behalf of a friend whio has bought a 2007 alphard and has had it parked up while he refurbs the wheels and does a few cosmetic things to it ,
my problem is it wont start anymore but i have a strange issue , the power mirrors and the windows and the sliding doors also climate and radio no longer work either , i put the key in the ignition turn it and get the display lit , the immobiliser light goes out but then when you go to startit nothing happens . battery is charged and ok ... any suggestions would help . if i also solve this before a reply i will post up what it was incase it happenes to anyone else. thanks in advance.
just for info i found the issue it was a 7.5 amp fuse on the passenger fuse box called am1 engine switch if anyone ever has issue
  • 2 years later...
I have the same issue on a recently purchased 2007 2.4l model.  I have replaced the AM1 fuse as suggested but this has not fixed the problem, any other recommendations?  Thanks Garry
Edited by gazzal
Hi Garry,
Is you battery in tip top condition, and fully charged.
I suggest you charge your battery and try again.
29 minutes ago, Rojie said:
Hi Garry,
Battery is good and fully charged, checked all main fuses, all OK, something very strange happening.
