Transmission Fluid Change for the 3.5 V6 (Not 2.4) ANH20 Alphard / Vellfire uses ATF WS and has been quite hard to get hold of.
I have seen a Toyota Dealer selling it for £25 a litre on amazon, yes you read that right. As its hard to get hold of they are making the most out of it.
I have just bought 7 litres for my Series 2 Alphard (bear in mind Alphard 1st series uses different fluid!!!)
https://lexuspartsdirect.co.uk/product/lexus-genuine-ws-atf-fluid-1l/
Lexus Parts Direct sell it for just over £10 a litre with a few quid delivery. A pound cheaper that Toyota Parts Direct. lol
Sometimes this does go on back order as there is a shortage ( an additive shortage)  so get some now or put yourself on back order if they run out. Other prices i have seen are £15 per litre, so Lexus Parts Direct have a decent price.
Hey thanks for the info 👍🏼
My 2.4  20 series (Cvt trans) had the 'TC' Auto oil. This was indicated by the stamp on the oil filler nut. I think there is also an FE oil.
I purchased mine from opie oils at a decent price.
They may be a good shout if anyone has trouble finding hard to find oils.
Resurrecting this thread from the dead.
My local Toyota dealer has agreed to do a fluid change for me (AH20 3.5), their car computer system connects up fine.
The reason for taking it to a dealer rather than DIYing it is that the gearbox oil needs to be at a specific temperature (and therefore volume) to get the levels right.
I'll post here when complete (including how much it cost.
Yes thats correct, we did this ourselves and requires a JOBD reader (icarsoft do one for Japanese Toyota)
you top it up on the side sump plug until the fluid comes out the bottom sump plug and stops dripping. put sump plugs back in and run to a temprature then open the plug again and let the warm fluid drain out until it stops dripping. The warm temprature makes the fluid expand.
its weird.
There is a proper manual sheet for this where you follow bit by bit. I will try and find it
Cheers for that, it's a different fluid for the 2.4 CVT, presume a different process too?
  • 3 months later...
Hi. I have a 2009 Vellfire.
My cvt fluid is TC. I'm aware that FE cvt has a straw indicator to let you know when it's full.  In my van there is no straw indicator it's just like an common engine oil sump bolt and there is also a small Allen key type bolt on the pan too. So there is 2 x bolts on my cvt pan. Any body has any knowledge/ experience mind sharing please 🙏
I had the transmission oil "service" a few months ago. It was £500.
I picked up the car and they'd done a drain and fill, but hadn't dropped the pan and changed the filter. I should have asked exactly what they'd quoted for, but I'd assumed "service" and £500 meant the full thing.
I'm now looking for a specialist garage that isn't the Toyota garage in Basingstoke 🙂
  • 6 months later...
ouch that is expensive as its less than an hour, in fact 30 min job if only draining fluids.
Tranmission specialists will do it for 250 mark.
We did it ourselves as Just needed the OBD reader, Fluids and filters. Follow the guidelines (these are important as requires right temperature)
Hi did you get it done, I have a vellfire 3.5 4wd and looking to get mine done at it's nearly hit 100kmiles
Yes, I did. I reported back in the comment above here.
