Powered doors won't close
Hi all,
Thanks for allowing me to join the forum.
I was wondering if someone could help and give some advice regarding my powered sliding doors.
The sliding door will open correctly but when I go to close it will only go halfway then open back up again.
I can't see an obstruction that will cause it to open back up again.
When I have to close it by hand, I have to use great force in doing so.
Any help on this will be greatly appreciated.
cheers
Edited by robstarrob
Clean up your rail with WD40, dry with contact cleaner and apply with spray grease, every month better.
When it's been sticking have you de-selected the power door button on the dash?
Hi Alasdair
Yes I have tried with the power door de-selected. It takes quite a bit of force too close it.
I agree with Setuffo that there must be something about the rail causing this issue
Rail or cable. You will need to inspect both to find the issue. DON’T apply grease to the rail as suggested as this will attract dirt and in no time will make it much worse.
Martylew, this sliding door aka power door design to lubricate and maintenance frequently to prevent jammed or wire broken, almost every month I see this problem in our workshop.
Hi
I had exactly the same problem 2 years ago, door eventually jammed half open in a thunderstorm!
It was indeed a snapped cable, I believe the cable assembly consists of two loops of cables,  and a plastic lug  was jamming the mechanism...someone here with better technical knowledge  may explain better.  Anyway the nice guys at Stuart Spencer Autos in Tipton put in a new cable under warranty..no problems since. I now coat with silicone spray which doesn't seem to pick up dirt.
I will get my engineers at work to look at the door and get them to lubricate as you described earlier in this thread.
thank you for the advise.
8 minutes ago, PZsurf said:
Hi
Hi Mate
if you don't mind, can I ask how much this cost please.
49 minutes ago, robstarrob said:
Hi Mate
The whole mechanism has to be replaced as the cable is not available separately, look on ebay for sliding door cable assembly. what happens is the plastic outer covering on the cable gets brittle and breaks off and jams the pulleys and motor, if cleaning the runners does not make it easier then if you cut the cable where it runs in the channel under the rear quarter window it will release the tension and allow the door to be opened/closed manually
Yes, lub but not with grease. Light oil, silicon spray 👍
Hi
Sorry can't help with the costs involved as it was a warranty job and they sourced the parts needed.Best ring round a few of the good specialists near you. As Dezufo says, it was the whole assembly needed changing.
Good luck
I had similar problem and had to cut and remove the broken cable. Replacement cable kit is about£200. I lead quoted about£250 to fit it but only at end of season when not busy doing conversions so haven’t replaced it yet and just use on manual on that side
Afternoon All
Just to give an update for anyone that had been following this thread or for future reference.
I had my engineer at work look at the door. He pumped the area with lube and noticed that the plastic casing on the wire had corroded and broken up.
The more lube we sprayed and pushing and pulling the door back in manual mode helped to move/shift the broken plastic.
My door is now operating as it should in automatic mode. However, there will still be more plastic inside the door and tubing that the wire goes through. So I will have to open the inside door panel and remove and clear all plastic.
In the long run I will have to replace the wire completely.
Many thanks to all that contributed to helping me resolve this issue.
Cheers
Rob
I have a similar problem with my passenger door on closing. It goes all the way into the aperture but the rear edge remains out about 10mm and therefore doesn’t latch closed. I can push it in and it then clicks and latches. any ideas on what is wrong (It’s a 2004 model) - it always opens electrically by the dash switch and outside handle but I’ve noticed it being intermittent when opening from the interior handle- sometimes not unlocking to open manually. Thanks for any guidance.
Did you manage to resolve this? I had a similar problem with the door not automatically clicking onto the rear latch after replacing my cable assembly following a jam.
All appeared to work other than need to push it manually for the last 10mm to get it to click onto the rear latch.
I tried to work out what the issue was by opening and closing and the the new cable jammed.
I'm now reluctant to buy another until I figure out the cause of the 10mm issue with the latch.
Any help appreciated.
  • 4 months later...
@dave1066 and @Tonyp were you able to fix the door not latching? I just ran into similar situation with mine. If so, can you share the fix?
Happened to me last year. Sheathing on the cable had disintegrated and cabled had got wrapped around door mech. Had to get whole power door motor mechanism replaced. Cost about 400 quid int total  as I recall.
