ianandrews Posted June 6, 2023 Posted June 6, 2023 Hi. New member here 🙂 I need a new n/s (passenger side) handbrake cable for a 2004 2.4 Alphard as the existing 1 is seized solid - luckily in the off position. I can't find a new or used 1 anywhere so wondering if any members know of any availability..? Thanks 👍
Rojie Posted June 6, 2023 Posted June 6, 2023 1 hour ago, ianandrews said: Hi. New member here 🙂 I need a new n/s (passenger side) handbrake cable for a 2004 2.4 Alphard as the existing 1 is seized solid - luckily in the off position. I can't find a new or used 1 anywhere so wondering if any members know of any availability..? Thanks 👍 Hello Ian, Welcome to the Forum.
MonsterS Posted June 6, 2023 Posted June 6, 2023 3 hours ago, ianandrews said: Hi. New member here 🙂 I need a new n/s (passenger side) handbrake cable for a 2004 2.4 Alphard as the existing 1 is seized solid - luckily in the off position. I can't find a new or used 1 anywhere so wondering if any members know of any availability..? Thanks 👍 Check the length. You might find it from another vehicle. On ebay there are the right and left side. ns one This may be the blueprint version. Not sure if it fits though check the measurements.
