Peep-peep annoying noise from fridge area
There is an annoying “peep-peep” sound from fridge area on our Alphard Camper,both when engine is on or off. And where can l find a user’s Manual for our vehicle for which we are pleased to have bought 2 years ago. Also what are correct tyre pressures. The kitchen and cupboards are on the driver’s ,s side. Thank you
1 hour ago, Nella said:
There is an annoying “peep-peep” sound from fridge area on our Alphard Camper, both when engine is on or off. And where can l find a user’s Manual for our vehicle for which we are pleased to have bought 2 years ago. Also what are correct tyre pressures. The kitchen and cupboards are on the driver’s ,s side. Thank you
Hello Helen,
What type of fridge do you have ?
JPNZ Owners Manuals, in English, are usually available on ebay.
One of the members was selling one recently.
They are not Maintenance Manuals; if that is what you are looking for.
Tyre pressures are 230kPa or 2.3kg/cm2; 32 to 33 psi.
You will need to contact the firm that fitted the units or at least the maker of the fridge. Owners manuals are availble on ebay or amazon. Tyre pressures on a camper should be 38psi, advise you google the 4psi rule and follow the directions and adjust the pressures accordingly
19 hours ago, Rojie said:
Hello Helen,
This is for a standard van.
The beep beep noise is most probably a high temperature warning. Your fridge is either too warm or the sensor is faulty.
