Just quick question
How much oil do you need for replacement in 6 speed auto .
.....and no i Don't need dry fill anount which is 6.5l .
I am after real figure as about to buy fluid and trying to keep on low price
The other way drain it see how much comes out, not changed it on the vellfire but have on a Elgrand and Estima used to fill it until it starts seeping out the filler plug, and always loosen/remove the filler plug first before drain.
Edited by Philllx
   I have recently replaced the filter in my 3.5 Vellfire 6 speed auto box. The drain plug has a plastic tube behind it (this is the to set the level) the tube also needs to come out to drain the fluid this is removed by an Allen key. I bought 4 litres of genuine Toyota ATF WS from ebay ''expensive''. I topped up after replacing sump and filter and used about 3.5 litres. There are a few videos on u tube about changing filters and fluids on the U660e gearbox.
You just perfectly answered my question.  As to fluid evay or main dealer?
Ebay £15 /L its not that bad
Btw did the change and in 6 speed auto the most you will use is 4L at best . I did suck out of cooler so did bit more
