Hi all.
Hoping to find some answers?
What are the symptoms of a total inverter failure? (will the vehicle start / run?)
What are the related codes on the ODBII?
Will replacing the inverter fix the problem? or is system complex and has many points of failure outside of the inverter box?
Cheers,
Mark
There is a long list of Toyota fault codes on the link below. Hope this helps.
Hybrid specific dtc codes | Toyota Nation Forum
If the inverter is faulty there may be other reasons for it such as the failure of the inverter cooling pump causing overheating or a blocked radiator core causing the same.
There are forum members who have changed inverters so hopefully they will respond.
