Passenger side electric windows not working
Hi
Everything electrical on the van is working fine - except the passenger side electric windows (front passenger and side door) are not working - either using the driver's controls or the passenger controls. They just seem to have stopped. It is perhaps associated with the various other issues I have had with the electrics.
Any ideas? Might it just be a fuse or other thoughts on what it might be? Some need to reset?
Regards
Put key in ignition to battery light press and hold drivers side window switch let window go right down hold switch 10 seconds let it back up go to window behind drivers seat do the same again then go passenger window back do same again then do front passenger window do same again always remember to hold button down 10 seconds then done go drivers side switch and try all windows this should reset all windows
Edited by Picasso
Spelling
