AH20 Alphard/Vellfire rear door struts.
20240524_133904.thumb.jpg.f81c4ee9c4a4c3f04a4100a7cf417edb.jpg20240524_133914.thumb.jpg.0294c3f3982663af7ca36e60e24609bc.jpg
20240523_114002.thumb.jpg.e621dc23242bb2cec08caead43eebb1e.jpg20240523_113949.thumb.jpg.f99eae82c33196d3a69d13996a425962.jpg
Hi. I have a 2008 Vellfire AH20. I've mentioned before, and it has been mentioned by other people about the height of the rear door, when open, being too low.
My struts went up the the fully open position if lifted, but wouldn't lift themselves all the way up.
Time for a replacement!
Had a look on the internet and one company sent the wrong ones; too short and no brackets, even though recommended for Alphard/Vellfire's. I hot a refund in 4 days and had ordered a new set that looked right (showed brackets, etc).
These arrived yesterday. I fitted them and they fitted perfectly! The cylinders ar shorter, but the close ok and, FOR THOSE WHO COMPLAINED THAT THEY BANGED THEIR HEADS,
they open the door about 2" to 3" higher!!! They lift the door as soon as you unlock, but you can still pull down and shut easily.
I'm really made up with them!
The make is 'XIANGSHANG'.
THESE WORK WELL and are highly recommended!!!
(See attached pics)
You don't have to bang you head again!!!
John Harrison. Wallasey
(See attached pics)
I have been considering replacing the struts on my MZG.
There are different versions depending on power door or not.
At the time, my local Toyota dealer could get them for 200ukp each !
Can you disclose the price you have paid for yours, please.
I'll check and see if they supply those for the power door version.
My door almost opens fully, I do need to be careful when stepping under the tail-gate from a kerb.
However, functional that it is, it judders while closing which annoys e intensely.
Hi. Yes, sorry.
I paid  about £41, including postage, from Ali Express Ltd.
John Harrison.
56 minutes ago, John Harrison said:
Hi. Yes, sorry.
John Harrison.
Thank you John,
At that price I'll probably give it a try.
Were they 'easy' to fit ?
Hi again. Yes very easy to fit, as long as you have someone or someone, to hold the door up while you remove the old ones....One heavy door!!!
John H
They do do electric ones, as well as electric kits with switches etc for between £200-£300. I think that will be p+p on top though!
John H
John H
Hello John,
Thanks for this; but my struts are not electric.
The tail-gate motor is, but not the struts.
I don't want the complication of additional wiring; but I will check them out.
Could I ask you please, when convenient, to measure the strut diameter.
I have previously imported 'suitable' struts which, unfortunately, were not suitable !
They have all different types!
John H
Hi John
Thanks for posting this- I just finished fitting the same struts from Ali Express. So nice to have it open fully and not keep banging my head. Pretty easy to swap them out. I used an acrow prop to hold the boot open, but had the wife holding it, as well as some cargo straps from boot to the roof bars in case of failure. I have memories of swapping out struts in the past where the prop fell over and the boot smashed down and blew out the back window.
Regards
Luke
Do you guys have the exact link for these struts on Ali? I've looked and there seems to be several listed.
Pete
Hi Pete
Here is the link:
Just found this amazing item on AliExpress. Check it out!
£45.79 | With Power Tailgate Struts for Toyota Alphard Vellfire AH20 2008-2015 Minivan Rear Trunk Lift Supports Shock Absorber Dampers
https://a.aliexpress.com/_EuGFovd
They come with new mounts that are slightly different to the old ones, but fit okay. You'll need a 12mm spanner/socket set. I have a powered boot, so you might want to buy a different set if yours is manual only (although they might work for both options). I found it easier to fit the boot end of the strut first, then the main body of the car.
usl
Just make sure the boot Is really well supported during swap over ,- they are much heavier than you think and will slam down fast and dangerous without both struts in place.
Ali Express will tell you it'll take 80+ days to deliver, but mine came within 10 days. (Not sure why the text has turned red here).
4 hours ago, LukeyLukey said:
Hi Pete
Here is the link:
usl
Thanks Luke, just placed an order.
Pete
I found some on Ali Ex, supposedly, suitable for my power tailgate.
£35 shipping; almost as much as John paid for the delivered item.
More searching needed !
If they fit and work, a real bargain as Toyota wanted £200 each !
I paid £37.67 for the parts and delivery. They said it would be 80+ days for delivery, but it was about 1 week. It was my first time using Ali Express (I've tried wish and joom with mixed results). They seem to be as good quality as the original struts. I think they need replacing every 10 years or so.
Good luck,
Luke
Good luck,
Luke
I paid £37.10 inc delivery, a good price. My rear door doesn’t drop but I have to help it open all the way, not a problem but it’ll be nice for it to open itself with an initial push.
On 5/25/2024 at 11:49 AM, Rojie said:
Hello John,
Hi. Sorry about the delay in replying.
The diameter of strut cylinder is 23.5mm.
Cylinder length 306mm.
Overall length between strut centres is 575mm.
They are for non motorised door and come with the fitting brackets already on each end.
I don't know any numbers I'm afraid, just that they were under 2008 2.4 Alphard/Vellfire type AH20.
Hope this is a help?
Hello John,
Thank you for this.
I appreciate it.
They look just like mine; and my machine is a Gen 1 facelift.
I bought some struts previously, but they did not fit.
I have been on Ali Ex and the ones for the facelift do not seem to come with brackets, which is OK.
I'll check my the measurements against those you have supplied, thanks again.
I am also working with Lee to establish whether Gen 1 and Gen are the same.
I do know from the epc that there are different variants.
On 6/16/2024 at 5:34 AM, LukeyLukey said:
Hi Pete
Here is the link:
usl
 Mine arrived yesterday, so just over a week for delivery, fitted today, took no more than 10 mins to fit with the help of my son holding up the door 🤣 Door now lifts itself all the way to the top after an initial pull, so much easier although it wasn't a problem, just nice that the struts now do the work. 👍🏻
Nicely done. I spent about 40 mins due to my crazy 3 lines of contingency to ensure I didn't repeat my previous glass-smashing foolishness. Glad this fix worked for you, and thanks again to John for sharing the OP.
Yep Cheers John 👍🏼
Hello John,
Hi. For some reason, I must have missed your question; sorry it'd been so long replying.
The cylinder length is 12" long (304.8mm) and cylinder diameter is 23.5mm (59/64").
These work well on my Vellfire and were bought from Ali Express.
The first ones I ordered were wrong but they were refunded very quickly and I ordered these that are correct.
Good luck!
John Harrison Wallasey, Wirral.
Good luck!
Thanks for this update. I appreciate it.
I am currently awaiting a quote confirmation from Amayama.
I provided my vehicle details and, surprisingly, they asked me to confirm them; which I did.
I had previously ordered a set, but they were the wrong ones; so I am being more thorough this time.
What I was initially quoted, before they requested confirmation of the frame number, was about £70 each but that was for Toyota OEM items.
Status ? Ongoing !
I paid £41 inc carrier, bur I have seen them since for £28!!!
John Harrison. Wallasey.
