On 5/24/2024 at 1:51 PM, John Harrison said:
20240524_133904.thumb.jpg.f81c4ee9c4a4c3f04a4100a7cf417edb.jpg20240524_133914.thumb.jpg.0294c3f3982663af7ca36e60e24609bc.jpg
20240523_114002.thumb.jpg.e621dc23242bb2cec08caead43eebb1e.jpg20240523_113949.thumb.jpg.f99eae82c33196d3a69d13996a425962.jpg
Hi. I have a 2008 Vellfire AH20. I've mentioned before, and it has been mentioned by other people about the height of the rear door, when open, being too low.
My struts went up the the fully open position if lifted, but wouldn't lift themselves all the way up.
Time for a replacement!
Had a look on the internet and one company sent the wrong ones; too short and no brackets, even though recommended for Alphard/Vellfire's. I hot a refund in 4 days and had ordered a new set that looked right (showed brackets, etc).
These arrived yesterday. I fitted them and they fitted perfectly! The cylinders ar shorter, but the close ok and, FOR THOSE WHO COMPLAINED THAT THEY BANGED THEIR HEADS,
they open the door about 2" to 3" higher!!! They lift the door as soon as you unlock, but you can still pull down and shut easily.
I'm really made up with them!
The make is 'XIANGSHANG'.
THESE WORK WELL and are highly recommended!!!
(See attached pics)
You don't have to bang you head again!!!
John Harrison. Wallasey
Hi John, can you confirm that I have ordered the wrong ones, which came without the brackets..? But it does says it's for 20 series, with power tailgate? Thanks in advance!
