Hi all, had my 2010 alphard 2 years and love it, great for holidays with the 2 spaniels!
I do have a problem though, the rear doors close but don't seal at the bottom, meaning wind noise and a draft if I put my hand down near the bottom. How do I adjust the door to hopefully eliminate the issue, is it common?
You mean the side doors or the boot?
Tue boot cam be adjusted by undoing the bolts on the closing mechanism.
The side doors should have guiders to secure them into and a auto pull close motor (this is not the same as the closing motor which can be operated by the driver, ots the final soft close motor) if both doors are the same then look and see you have a fuse gone. Normally it goes and the soft close stops causing a gap at the bottom of the door
It's the side doors, the boot is fine. I will check the fuses, many thanks!
