Lynnie Posted July 8, 2024 Posted July 8, 2024 Can anyone help me, I have a problem with Side lights, fog lights front & back , number plate light on my Alphard, electrician says its not the fuses, so I am now struggling, does anyone know how I may solve the problem. The radio has also stopped working, I am hoping they are all connected, any help greatly received. Only had Dexy for a year, and now unable to drive until sorted. Thanks to anyone reading that can help.
Picasso Posted July 8, 2024 Posted July 8, 2024 Sounds like fuse to me has he checked all the fuses even the ones located behind the glove box it's hard to find this fuse box unless they know where to look
Lynnie Posted July 8, 2024 Author Posted July 8, 2024 Hi, yes he checked all fuses there, I was really hoping it would be that, unfortunately not.
Picasso Posted July 9, 2024 Posted July 9, 2024 Before you noticed these not working have you had any work done on the alphard
Lynnie Posted July 9, 2024 Author Posted July 9, 2024 The rear camera stopped working after having a leisure battery and diesel heater fitted, I also had a new battery fitted, have only just noticed as it failed mot.
Rojie Posted July 9, 2024 Posted July 9, 2024 On 7/9/2024 at 6:29 AM, Lynnie said: The rear camera stopped working after having a leisure battery and diesel heater fitted, I also had a new battery fitted, have only just noticed as it failed mot. Expand Hello Lynne, Are you suggesting that your van failed the MOT for a non functional rear camera ?
Lynnie Posted July 9, 2024 Author Posted July 9, 2024 No it failed on the lights, fogs, tail and number plate, the camera also not working which was useful as I'm not the best reverse in the world
Rojie Posted July 9, 2024 Posted July 9, 2024 On 7/9/2024 at 8:04 AM, Lynnie said: No it failed on the lights, fogs, tail and number plate, the camera also not working which was useful as I'm not the best reverse in the world Expand Yes, the camera is very useful when reversing; I would really struggle without one. Those failures don't seem serious. Hopefully you will be 'on the road again' very soon. 1
Picasso Posted July 9, 2024 Posted July 9, 2024 i still think this is a fuse issue when having the parts fitted somthing has blown to protect the electrics would be a fuses blowing first have a chat with paul at new acre cars he been importing these cars for many years he in evesham so would say not that far from you 01386 718602 he knows his stuff 1
Geralt Posted July 10, 2024 Posted July 10, 2024 On 7/9/2024 at 8:04 AM, Lynnie said: No it failed on the lights, fogs, tail and number plate, the camera also not working which was useful as I'm not the best reverse in the world Expand This points to the TAIL fuse. The TAIL fuse is hidden in the passenger compartment. https://car-box.info/toyota/previa/alphard-h10-2002-2009.html Are you sure the sparky has found and checked those fuses as well? They might have only checked the easy-to-find fuses in the engine compartment.
Lynnie Posted July 10, 2024 Author Posted July 10, 2024 Hi, I was watching as he looked at the fuses in the glove box, he said he tested all, so not sure what to try next. Spoke to an Alphard owner who said tail light, fogs, and side is in the driver side fuse box but all diagrams say not, thank you so much for helping. I hope to find a solution soon, everything crossed 🤞🤞
Picasso Posted July 10, 2024 Posted July 10, 2024 I agree with Geralt on this get a 2nd opinion and have the fuses checked behind the glove box it's a pig to get to
Rojie Posted July 11, 2024 Posted July 11, 2024 Yes. The fuse box is behind the glovebox, which needs to be removed (simple to do). It is a real pig to get to. You may be lucky to even see it as it is buried underneath an array of cables. The TAIL fuse is 10 amp, and is in the passenger side footwell. Position 13. I have concerns that your electrician was looking in the correct fuse box, let alone checking any or all of the them. If you are nimble, have good eyesight, and a mirror; you may be able to do it yourself. I believe the fuses are micro size. Get one from your local Toyota dealer BEFORE you start. 1 1
Lynnie Posted July 11, 2024 Author Posted July 11, 2024 Thank you, I will try found the location and can see them it all looks clean and tidy in there, perhaps he was checking the wrong one, should I count with the toyota name at the top? As it is on the bottom on my board.. Silly question but they aren't numbered. Sorry if this is a silly question, I will try and take a photo of it later.
Picasso Posted July 11, 2024 Posted July 11, 2024 hello lynnie i have atatched pages of location off fuse no.s behind glove box 1
Lynnie Posted July 11, 2024 Author Posted July 11, 2024 Thank you so much, would you have a wiring diagram for the 2002 3ltr as well, or know where I may get one, a thankful Lynnie
Geralt Posted July 12, 2024 Posted July 12, 2024 (edited) On 7/11/2024 at 8:27 PM, Lynnie said: Thank you so much, would you have a wiring diagram for the 2002 3ltr as well, or know where I may get one, a thankful Lynnie Expand There's three options: 1) 2) Contact @FrenchDJ. 3) Edited July 12, 2024 by Geralt 1
smurf Posted July 12, 2024 Posted July 12, 2024 On 7/11/2024 at 8:27 PM, Lynnie said: Thank you so much, would you have a wiring diagram for the 2002 3ltr as well, or know where I may get one, a thankful Lynnie Expand Send me a PM with your email address. I can help you with a link to the manual with wiring diagrams in English. 1 1
