Hello
my 54 plate 2.4 alphard hybrid has worn axle bushes and ? Bearings (the rubber mounts the axle sits on)?? Sorry but not sure of the correct term but they are all the rubber left oking pieces!
please can somebody tell me the proper names and part numbers for my vehicle and if you have any suggestions where to source them it would be appreciated. Thanks.
is it a big job to replace them and any ideas of likely costs please?
thanks everyone
Thank you Picasso that is very helpful and much appreciated. James
Are there similar for the front and beneath on the rear axle?
Yes thank you but I have a similar problem at the front. I think this might be a picture from the front?
is there a complete kit for all the bushes as I suspect all may be equally ‘unwell’!
thanks again.
thank you again really appreciate your help.
Looking up the parts it ask me if my hybrid is 96KW or 117KW. I have looked through my papers but can’t find out which it is. How can I find out the model please
All early 10 series hybrids are 96kw at 5600rpm.
(109kw including the hybrid motors)
Thank you Jess. That’s very helpful.
They will need a forklift to remove the axel. Mind was done within 2 hours. A good mechanic will do it quickly.
Please does anyone have a link to source front and rear brake pads and fitting kits for my 54 plate 4WD 2.4 hybrid Alphard?
have looked on eBay but not sure which are good ones or the right fitting kits! Thanks
Hello James can you please give me your reg no. Pm me it if you want to
