Had my GGH25 nearly two weeks now, and have realized it has the Intelligent Parking Assist function (in Japenese unfortunately). I have the 18 speaker stereo and head unit, so no easy switch to English as far as I know. (OEM head unit is the BT-013A with DVD/CD/TV and minidisc)
My primary question about the ECU is does anyone know whether the Japanese text/speech for the cameras/IPA  comes directly from the ECU or is provisioned when it hits the head unit?
I come from a computer tech background so considering whether I can get this working into another head unit.
The ipa unit under passenger seat.
It feeds data via a a gvif connection.
The ipa is itself fed data from the 3 cameras, steering angle and sonar sensors.
In aftermarket systems, a gvif to poor quality phono connection is possible, so essentially just a video feed to provide to the new headunit, because you lose the direct feedback mechanism via gvif, i don't belief the self parking works anymore as you cannot select on screen where the car should target itself.
You should be able to retain the swapping between cameras via the button above the engine start button.
Chris, Any idea whether the missing control signals are on the GVIF i/f or I imagine  there might be a canbus link somewhere?
Something must be transferring from headunit screen presses, to the ipa, but I've not looked into off it is via the gvif or the canbus.
I attach wiring diagram, you will see both can and gvif connections, there are also lin connections for the sonar
IPA-2.pdf
Still researching..it looks like there are quite a few different comms channels used by toyota, not just canbus.. will be interesting.
Gradually assembling hardware, have a dudoauto android head unit, plus factory amp retainer, and the GVIF to RCA adapter, but first I will need to analyze whats going on in the existing system. Have a range of protocol analyzers available, just need time to pull the passenger seat and find time to investigate, probably over xmas.
Will update with any findings.
Limited Update
I've sifting through all the wiring diagrams I can find, and it appears the IPA ECU shares Canbus, GVIF and AVC bus connections to the head unit.
I've never seen AVC bus support mentioned on an Android head unit, so that may be challenging.
On a related note, I've been working through the 18 speaker theatre sound setup, and the so called canbus/most adapters for Android head units. From what I can tell these adapters only use a stereo output from the Android head unit to drive things, not the full 5.1. I've certainly not seen one that does better. If anyone has spotted a better one I'd like to here about it.
Hopefully start to do some limited signal/protocol analysis next week.
