Hello
I cracked my front bumper attempting a turn in a tight space. Looks like it needs replacing. Can anyone point me in the right direction in terms of getting a new one.
I found a couple on EBay but they are quite badly scratched. I would prefer a new one or one without any damage.
The only place to get a new one is from Toyota Direct which can ship from Japan, but be prepared to pay hundreds of pounds for one. Other than that you can try Aliexpress
Great, thanks for the response. Just to clarify on Toyota direct. I can contact the UK site and they should be able to source from Japan?
Also, I found a site called Amayama. Seems they have a comprehensive list of parts, although quite difficult to navigate. Are these guys legit?
Cheers
Lets see a photo. You may be surprised to know that there's are lot of Tec's out there who, in a lot of cases, are able to fix plastic damage to external panels of vehicles Theres are a lot of external plastic panels on Alphards, Vellfires etc etc😃
Thanks for your reply. I've attached a couple of photos. Someone has suggested it could be plastic welded. I have no clue about this.
Hi, a couple on eBay at the moment,
It  might repair with hot staples.
Hi we unfortunately bumped ours a lot worse then that so we had one priced at toyota it was £1000 colour coded but not fitted.
They can be plastic welded and repaired then resprayed I did my own so no idea what a garage would charge.
