Morning.
Any idea what this box is connected between the battery terminals ?
The light comes on when button is pressed.
Thanks for any info.
Is your Alphard a camper conversion,if so it could be for charging the leisure battery. Perhaps someone will confirm this.
That looks to be a home-made contraption. You could undo the screws on the back and take a picture of the insides, that might give a clue. Does the button lock down or does it just pop back - if the latter I would suggest it is used to check that the battery has enough charge - 12v and it lights up, less than that it doesn't.
Thanks for replys. It's not a camper.
The button pops back up so yes it's probably a battery check.
Tnx again.
where does the cables terminate too ?
They just go to the battery terminals.  One to each side.
looks to me that this could be a device that basicilly stops the ignition being turned on to stop theft of your vehicle ?
I think this was ET's latest attempt to phone home.
Open the box and take a photo and we can stop the guess work 😀.
Interesting. you may be right.
My hands don't work properly but I'll get someone to open it in a few days.
But wired straight across the battery ? I hope not.
In series with one connection, perhaps, but there are mush better, and safer, ways and devices exactly for that purpose.
I  suppose one idea would be to disconnect the whole"unit"and see if every thing still works.If every thing is still OK, I would take it off the battery and put in your shed!!!
It could be a very, very, crude voltmeter.
Unless a battery is under some load voltmeters are of very limited use as they will read high when not supplying current.
And having it on a momentary switch would be pointless.
