Replacement Headlight / High Beam
Hi all
Sorry if this has been asked and answered before. My 2009 has very weak headlights, so I'm thinking of replacing them with LED lights. Does anybody know the type
Also my high beams have ballast connected. One side packed in so I purchased a replacement set, exact same spec but the connections are loose and they keep playing up, wo I would like to change these for LED high beams that I can plug directly into.
Thanks in advance
HID low beam D4S, I have a set on the way... high beam 9005 I believe.
My low beam HID is a D2R, took it out last night as I too want to improve it. I'm hoping the bulb has aged and that's the trouble. 20241208_150903.thumb.jpg.c472814404a52d04a7396f4ac41eade7.jpg20241208_150903.thumb.jpg.c472814404a52d04a7396f4ac41eade7.jpg
If you have HID projector then that's the wrong bulb. "R" means it's for reflector. All projector headlights should use "S" bulb.
Hi @opelrsx
Ooh looks like one of the previous owners have fitted the wrong bulbs then!
Could explain why they aren't as good as I expected too I guess!
Thank you for that info, I'll go and see my local guys for a new pair!
I feel they are still very weak, at least on mine... I prefer HID over LED bulbs but cannot find a shop to do proper HID projector retrofit in my area. Still waiting for the LED bulbs to show up, hopefully they will be better...
23 hours ago, Voodoo101 said:
Hi all
Thanks in advance
Chris.ac produced a definitive bulb list to the Alphie.
Your may wish to check his topics (there are quite a few !).
Thank you to all. I have been looking on Amazon but not too sure of the quality
Arrived, looks not bad... let's see how it works shortly 😃
Put them on, telling from my eyes, probably 10%-20% brighter than stock HID. No complaint though, still using stock ballast and projector, so cannot expect huge improvement.
Edited by opelrsx
  • 4 months later...
On 12/15/2024 at 2:57 PM, Voodoo101 said:
New high beams sorted. Out with the ballast and new LEDs wired direct. Work, fit perfect and gives me less connections to worry about.
https://www.amazon.co.uk/dp/B0D7VCBCBK?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Have you still got these fitted and how are they working out for you, any problems?
Yes I still have these fitted. I have two sets of brand new Ballast sat doing nothing. LEDs are working perfect. I changed the headlights aswell and I can actually see now when its dark
