At what sort of mileage would you be expected to change transmission fluid in a 2010 3.5
I'd say at about 15 years old or when I just bought it 😄
As that's what I did personally.
It's not too hard at all, but you do need to be able to see transmission fluid temp to get the level right with the "overflow tube" method it uses.
I think I will give it a go given its not a difficult job
I'm following the recommendations of "The car care nut" on Youtube, who was a Toyota mecanic and used to 2GR & the 6 speeds auto gearbox with it.
So those are the following :
Auto gearbox oil change : 100k km (62k miles) OR 6 years
And for the history I'll let others infos there :
Cooling liquid change : 80k km (50k miles) OR 5 years
Brakes fluid change :  3 or 4 years (or you can use a cheap tester too)
2GR-FE spark plugs change 100k km (62k miles) OR 10 years
I did the filter as well, if you take the sump off be aware there is still about a litre and a half of fluid, have a bowl under there!
Edited by BigNev
Sorry, it's only about a litre, still plenty to get messy!
Depends on transmission if you have 2.4 2AZ-FE then at 6 years or 60000Kms. You can do a flush or drop sump and replace filter though this is not absolutely necessary if you change fluid at schedule.
