JAD Posted March 17 Posted March 17 Hi This light has started coming on all the time. I've checked all the lights and they seem OK. I also checked for fault codes and it didn't find any. Any idea what is causing it and how I sort it? Thanks John IMG_3723.HEICFetching info...
Rojie Posted March 17 Posted March 17 On 3/17/2025 at 1:30 PM, JAD said: Hi This light has started coming on all the time. I've checked all the lights and they seem OK. I also checked for fault codes and it didn't find any. Any idea what is causing it and how I sort it? Thanks John IMG_3723.HEIC 876.83 kB · 0 downloads Expand Headlight auto levelling light. Have you had your rear bushes changed recently ? Have you changed the wheel tyre combinations recently ? I assume you have HID lighting. Do your headlights adjust upwards when you first start the car in the dark ? You may have a ballast resistor failure.
JAD Posted March 17 Author Posted March 17 Hi thank you for the reply I have changed all four tyres recently. I will see what it does in the dark. Cheers John
Rojie Posted March 17 Posted March 17 On 3/17/2025 at 7:27 PM, JAD said: Hi thank you for the reply I have changed all four tyres recently. I will see what it does in the dark. Cheers John Expand Did you replace your tyres like for like in size ?
JAD Posted March 18 Author Posted March 18 I think they are the same size. I checked in the dark tonight and the lights did seem to go up and down when I started it up. Never knew it did that 😉 I don't think it has been driven in the dark since I had the tyres replaced. I will check on Thursday if light on the dash still on. Thanks John
JAD Posted March 24 Author Posted March 24 Although the light disappeared for a couple of short journeys it came back on yesterday grrr. Any suggestions as what I can do to try and sort please. Cheers John
Rojie Posted March 24 Posted March 24 On 3/24/2025 at 5:53 PM, JAD said: Although the light disappeared for a couple of short journeys it came back on yesterday grrr. Any suggestions as what I can do to try and sort please. Cheers John Expand When was your last MOT ?
PeterD Posted March 25 Posted March 25 Hi John, I am interested in how your investigations turn out. Our Alphard Hybrid has just had 4 new tyres fitted and the Headlight auto levelling light has come on. I didn't even know that headlight auto levelling was a thing - our everyday car (Honda Jazz) has a little control to adjust main beam high manually. Our Alphard "support", CampervanCo Scotland have gone into liquidation so we don't have anyone to go to locally to ask about such things. Peter D.
Rojie Posted March 25 Posted March 25 On 3/24/2025 at 11:00 PM, JAD said: Not long ago when i got the tyres changed. Cheers John Expand Were the tyres fitted before or after the MOT ?
PeterD Posted 20 hours ago Posted 20 hours ago Hi Guys, do we know why the "Headlight auto levelling light" comes on and what to do to fix it?
Picasso Posted 19 hours ago Posted 19 hours ago Hi have you checked the rear level sensor it self as there is a link bar that comes of it and attached to rear axle this some times snaps or sensor could be faulty
PeterD Posted 18 hours ago Posted 18 hours ago (edited) Thanks for the rapid reply. I didn't even know we had such a sensor before the recent forum post. So where do I actually look and what does it look like? Or is there a web link to this I can use to save bothering you? Regards, Peter D. BTW we have just had four new tyres fitted. Edited 18 hours ago by PeterD Omission.
