benzzy_ku Posted June 10 Posted June 10 I have warning light , check code is P1835, P1301-548, C1310 Can any one help me to clarify above code?
Picasso Posted June 10 Posted June 10 Welcome Theerawisit there is lots of members with the early hybrid problems im sure some one will be a long soon to help you .
Gamith Posted June 10 Posted June 10 Those codes could be old - have you cleared the codes and see which ones come back?
benzzy_ku Posted June 11 Author Posted June 11 14 hours ago, Picasso said: Welcome Theerawisit there is lots of members with the early hybrid problems im sure some one will be a long soon to help you . Many thanks 10 hours ago, Gamith said: Those codes could be old - have you cleared the codes and see which ones come back? I already delete code but after try to ride just only 500 meters the warning light show up and the code is same.
Gamith Posted June 11 Posted June 11 (edited) I have found these which may help - obviously not Alphard-specific but then the codes shouldn't be: https://carmodnerd.com/p1835/ https://carmodnerd.com/p1301/ (not sure about any in between these) https://carmodnerd.com/p1548/ https://carmodnerd.com/c1310/ Hopefully these help. Edited June 11 by Gamith
Jeza Posted June 16 Posted June 16 On 6/13/2025 at 11:10 AM, benzzy_ku said: Sorry for my mistake, It is should be P3101-548. P1835, This is not listed in the manual. P1820, P1825 and P1835 are referring to transaxle transmission revolution sensor and oil pressure sensor P3101-548, Abnormal signal received from engine control computer (CVT system abnormality) The hybrid vehicle computer performs fail-safe control based on an abnormality signal from the engine control computer (when the engine control computer detects an abnormality that may affect THS control). C1310-156 IG2 terminal voltage is 10.5V or higher for 1.5 seconds or more, and the traction control disable signal is received for 0.07 seconds or more while communication with the hybrid control computer is active. Hybrid control system (VSC, traction control malfunction). This is a normal fault code when the hybrid computer stops talking to the skid control computer due to a hybrid issue. As I don't think there is a kick down as such, you could check the accelerator pedal connector: Accelerator position sensor resistance check ../../img/a055961.png Use a Toyota electrical tester to measure the resistance between each terminal of the connector. SST 09082-00030 09083-00150 Reference value: Terminal number Reference value 2 (VPA2) ←→ 1 (EP1) 5.0kΩ or less 5 (VPA1) ←→ 3 (EP2) 5.0kΩ or less 4 (VCP1) ←→ 1 (EP1) 1.5-6.0 kΩ 6 (VCP2) ←→ 3 (EP2) 1.5-6.0 kΩ
benzzy_ku Posted June 17 Author Posted June 17 The code appear when i run a car with kick down up to the lamp. So it is abnormal from accelerator pedal ? Because I start engine 30 minutes without driving, the code did not show up. The engine is normal, Air condition is normal.
benzzy_ku Posted June 17 Author Posted June 17 After checked , below is show data to low. just only 0.519 kΩ Can you help me to clarify , What I should do? 4 (VCP1) ←→ 1 (EP1) 1.5-6.0 kΩ 6 (VCP2) ←→ 3 (EP2) 1.5-6.0 kΩ
benzzy_ku Posted June 17 Author Posted June 17 If the result is not match to your data, How should i do next?
Jeza Posted June 19 Posted June 19 If the resistance was high I would check the connectors at the ECU, I will find out the pins on the ecu connector to check out each wire.
Jeza Posted June 19 Posted June 19 I can't find anything in the manual diagnostics for this issue and why code P1835 is not in the manual. (in the previous post I said "P1820, P1825 and P1835 are referring to transaxle transmission" that should be P1845 not P1835. What are the symptoms when driving? What warning lights come on? Does the gearbox shift gears ok when accelerating? When checking the resistance above was that the harness connector or the position sensor connector? I think it should be the position sensor connector. hdam0480.pdf
benzzy_ku Posted June 20 Author Posted June 20 7 hours ago, Jeza said: I can't find anything in the manual diagnostics for this issue and why code P1835 is not in the manual. (in the previous post I said "P1820, P1825 and P1835 are referring to transaxle transmission" that should be P1845 not P1835. What are the symptoms when driving? What warning lights come on? Does the gearbox shift gears ok when accelerating? When checking the resistance above was that the harness connector or the position sensor connector? I think it should be the position sensor connector. hdam0480.pdf 125.55 kB · 0 downloads For now When I drive , the car is feeling like save mode, I have to push harder on accelerate paddle. Also the code that appear is P1825.
Jeza Posted June 21 Posted June 21 This looks to be a transmission issue, check the gearbox oil level, oil hot cycle the shift lever slowly though the whole range and back to Park. Check the transmission oil level with the engine running, top up if necessary with the correct oil, Toyota Genuine CVT Fluid TC. P1825/67 - When the READY lamp is on and the vehicle is traveling at 28 km/h or faster, the secondary pulley speed sensor (NOUT) detects a speed of 300 rpm or less for 2 seconds or more. Wire Harness or Connector Transmission Revolution Sensor Engine Control Computer If you can monitor live transmission data, (S2000 is the Toyota test tool): Inspection Procedure Step 1 S2000 data reading (secondary pulley speed) Connect S2000 to DLC3. Turn the ignition switch ON and read the secondary pulley RPM on the ECU data monitor according to the display screen of the S2000. Reference value: 0 r/min (when stationary) 2600r/min (at constant vehicle speed (approximately 60km/h)) The sensors are underneath the inverter of course!! The resistance can be checked by; Disconnect connector D of the engine control computer. Using a Toyota electrical tester, check the resistance between the engine control computer's vehicle side connector D13 (NOUT+) terminal and D20 (NOUT-) terminal. Reference value: 560-680Ω (20°C) Hope it is just the oil level! rab0716c.pdf
benzzy_ku Posted June 22 Author Posted June 22 7 hours ago, Jeza said: This looks to be a transmission issue, check the gearbox oil level, oil hot cycle the shift lever slowly though the whole range and back to Park. Check the transmission oil level with the engine running, top up if necessary with the correct oil, Toyota Genuine CVT Fluid TC. P1825/67 - When the READY lamp is on and the vehicle is traveling at 28 km/h or faster, the secondary pulley speed sensor (NOUT) detects a speed of 300 rpm or less for 2 seconds or more. Wire Harness or Connector Transmission Revolution Sensor Engine Control Computer If you can monitor live transmission data, (S2000 is the Toyota test tool): Inspection Procedure Step 1 S2000 data reading (secondary pulley speed) Connect S2000 to DLC3. Turn the ignition switch ON and read the secondary pulley RPM on the ECU data monitor according to the display screen of the S2000. Reference value: 0 r/min (when stationary) 2600r/min (at constant vehicle speed (approximately 60km/h)) The sensors are underneath the inverter of course!! The resistance can be checked by; Disconnect connector D of the engine control computer. Using a Toyota electrical tester, check the resistance between the engine control computer's vehicle side connector D13 (NOUT+) terminal and D20 (NOUT-) terminal. Reference value: 560-680Ω (20°C) Hope it is just the oil level! rab0716c.pdf 37.11 kB · 0 downloads Wow, your data is so clear, I will try to check and let you know later. Many thanks friends.^^
benzzy_ku Posted June 22 Author Posted June 22 If it is not oil level, What next damage parts you think I have to fix?
benzzy_ku Posted June 23 Author Posted June 23 On 22/6/2568 at 5 นาฬิกา 31 นาที, Jeza said: ดูเหมือนว่าปัญหานี้จะอยู่ที่ระบบเกียร์ ให้ตรวจสอบระดับน้ำมันเกียร์ สลับเกียร์อย่างช้าๆ จนสุดระยะและกลับไปที่ตำแหน่งจอดรถ ตรวจสอบระดับน้ำมันเกียร์ในขณะที่เครื่องยนต์ยังทำงาน เติมน้ำมันที่ถูกต้องหากจำเป็น น้ำมัน เกียร์ CVT แท้จากโตโยต้า TC P1825/67 - เมื่อไฟ READY ติดขึ้นและยานพาหนะกำลังวิ่งด้วยความเร็ว 28 กม./ชม. หรือเร็วกว่า เซ็นเซอร์ความเร็วรอกรอง (NOUT) ตรวจจับความเร็ว 300 รอบต่อนาทีหรือต่ำกว่าเป็นเวลา 2 วินาทีหรือมากกว่านั้น สายรัดหรือขั้วต่อ เซ็นเซอร์วัดการปฏิวัติเกียร์ คอมพิวเตอร์ควบคุมเครื่องยนต์ หากคุณสามารถตรวจสอบข้อมูลการส่งสัญญาณสดได้ (S2000 คือเครื่องมือทดสอบของ Toyota): ขั้นตอนการตรวจสอบ ขั้นตอนที่ 1 การอ่านข้อมูล S2000 (ความเร็วลูกรอกรอง) เชื่อมต่อ S2000 เข้ากับ DLC3 หมุนสวิตช์กุญแจไปที่ตำแหน่ง ON และอ่าน RPM ของรอกรองบนจอมอนิเตอร์ข้อมูล ECU ตามจอแสดงผลของ S2000 ค่าอ้างอิง: 0 รอบ/นาที (เมื่อหยุดนิ่ง) 2600r/min (ที่ความเร็วรถคงที่ (ประมาณ 60km/ชม.)) เซ็นเซอร์อยู่ใต้อินเวอร์เตอร์แน่นอนครับ!! สามารถตรวจสอบความต้านทานได้โดย; ถอดขั้วต่อ D ของคอมพิวเตอร์ควบคุมเครื่องยนต์ ใช้เครื่องทดสอบไฟฟ้าของโตโยต้า ตรวจสอบความต้านทานระหว่างขั้วต่อด้านยานยนต์ D13 (NOUT+) และขั้ว D20 (NOUT-) ของคอมพิวเตอร์ควบคุมเครื่องยนต์ ค่าอ้างอิง: 560-680Ω (20 องศาเซลเซียส) หวังว่าคงเป็นแค่ระดับน้ำมัน! rab0716c.pdf ขนาด 37.11 กิโลไบต์ - 0 ดาวน์โหลด After check with multimeter tools , the result is 0, nothing appear on monitor.
Jeza Posted June 26 Posted June 26 You could double check you have the correct pins on the connector, I have had this issue, by checking the good speed sensor in the transmission. Same connector as above but check between pins 12 and 19; Using a Toyota electrical tester, check the resistance between the engine control computer's vehicle side connector D12 (NIN+) terminal and D19 (NIN-) terminal. Reference value: 560-680Ω (20°C) If you get this resistance but nothing on the NOUT pins then you know it is either the sensor or wiring. I had a look at my engine to see if I could see the sensors, but no luck with the inverter cables, hoses and other cables in the way.
benzzy_ku Posted June 26 Author Posted June 26 8 hours ago, Jeza said: You could double check you have the correct pins on the connector, I have had this issue, by checking the good speed sensor in the transmission. Same connector as above but check between pins 12 and 19; Using a Toyota electrical tester, check the resistance between the engine control computer's vehicle side connector D12 (NIN+) terminal and D19 (NIN-) terminal. Reference value: 560-680Ω (20°C) If you get this resistance but nothing on the NOUT pins then you know it is either the sensor or wiring. I had a look at my engine to see if I could see the sensors, but no luck with the inverter cables, hoses and other cables in the way. I will try more and let you know.
benzzy_ku Posted July 5 Author Posted July 5 After renew Transmission Oil , This is the code i found.
benzzy_ku Posted Monday at 02:27 PM Author Posted Monday at 02:27 PM On 6/26/2025 at 3:14 PM, Jeza said: You could double check you have the correct pins on the connector, I have had this issue, by checking the good speed sensor in the transmission. Same connector as above but check between pins 12 and 19; Using a Toyota electrical tester, check the resistance between the engine control computer's vehicle side connector D12 (NIN+) terminal and D19 (NIN-) terminal. Reference value: 560-680Ω (20°C) If you get this resistance but nothing on the NOUT pins then you know it is either the sensor or wiring. I had a look at my engine to see if I could see the sensors, but no luck with the inverter cables, hoses and other cables in the way. Kindly help to review my error code, please
Jeza Posted Monday at 05:52 PM Posted Monday at 05:52 PM Do you have the data page for the HYBRID CONTROL ECU which will show gearbox speeds
benzzy_ku Posted Monday at 05:56 PM Author Posted Monday at 05:56 PM 2 minutes ago, Jeza said: Do you have the data page for the HYBRID CONTROL ECU which will show gearbox speeds When drive? or just on idle running?
