P3101-548
Abnormal signal received from engine control computer (CVT system abnormality)
The hybrid vehicle computer performs fail-safe control based on an abnormality signal from the engine control computer (when the engine control computer detects an abnormality that may affect THS control).
This points to the speed sensor on the gearbox as the signal goes to the engine ECU, then the hybrid ECU goes into limp mode.
P1825 is the speed sensor circuit NOUT (speed out), wiring or the sensor, there are no other connectors in the circuit.  Did you check the NIN circuit to ensure you have the correct connector and pins? Just to rule out the engine ECU being faulty!!
8 hours ago, Jeza said:
when driving
I will check for you.
On 7/8/2025 at 3:32 AM, Jeza said:
P3101-548
This sensor in below the inverter?
Yes, unfortunately.
Secondary pulley rotation speed sensor that detects the output shaft rotation speed is placed on the secondary pulley shaft (reduction drive gear), which is NOUT. This the top one on the diagram to the rear of the square shape bit of the gearbox.
rab0711c.pdf
On 7/12/2025 at 7:42 PM, Jeza said:
Yes, unfortunately.
I will try to fix it.
more and more and more problem, After replace speed sensor.
C1310 is a traction control malfunction, this normally occurs when there is a hybrid issue the computer stops regenerative braking and stability control via the rear motor.
P3009 When the insulation resistance between the high voltage circuit and the body is below the standard value. 10M ohm.
Defective parts listed include the inverter and all the cables that might have been disturbed during the sensor change. How ever, suggest clearing code switch off ignition then on again, not start, and after 2 mins check codes. P3009 relates to the main battery, HV, cables within the battery assy, which I guess you did not disturb apart from the service grip. It could be the main battery cables at the inverter which you disconnected.
Has the sensor replacement fixed that issue?
Now the code of sensor is not show up.
I will try to check code as you suggest and I will let you know again.
Now I have engine light warning on after drive 10 minutes, and check code have 2 codes.
1. P0325 Knock sensor 1 circuit (Bank 1 or Single Sensor)
2.P1885 SLS System Malfunction
Hi there!
For what it's worth, with the number of codes you seem to be getting, I would hazard a guess that it's actually very possible to be a wiring loom, or wiring connection, fault somewhere.
Or the connections to the 12v battery.
Fault codes are often generated when the electrical resistance, or voltage, from a component goes out of the expected range. So if there is something that is causing this, the computer thinks the item is faulty - not the wiring to it.
Water damaged cars are a good example, they can come up with "problems" a while after they dry out, and replacing the parts does not solve it.
Knock sensor
P0325/52 - When the knock control sensor is disconnected or shorted for 10 seconds or more at an engine speed of 2000 to 4500 rpm after the engine has warmed up.
Possible issues;
Wire Harness or Connector - ECU connector B, kah11476 pin 20
Knock Control Sensor - this is hidden under the inlet manifold, I read somewhere that it is possible to access it from going in from under the engine!!
Knock control sensor not tightened properly
Engine Control Computer
check the continuity between the engine control computer's vehicle side connector B20 (KNK1) terminal and the body earth.
standard: No continuity
1885/77 - When the hydraulic pressure command value is 0.5 MPa or less and the sensor output value is 3.0 MPa or more for 3 seconds or more.
Hybrid vehicle transaxle assembly
Disconnect connector D of the engine control computer.
check the resistance between the engine control computer's vehicle side connector D2 (SLS+) terminal and D3 (SLS-) terminal. kah11638
Reference value: 5.0-5.6 ohms.
I would remove all the ECU connectors, spray with electrical contact cleaner, check for damage, corrosion and damage to the harnesses. Also check in the gearbox area for any damaged wiring and check connectors ar seated correctly.
