Joel7513 Posted June 16 Posted June 16 Hi all I’m two years into Vellfire ownership and have been advised I need new disks and pads due to wear (I was expecting this) I cannot locate the spares on the normal sites like eurospares etc. Not sure if this is because I have personalised plates put on or whether it’s because it’s an import. could anyone help with part numbers or the like for disks and pads all round please? 2010 3.5V6. thanks in advance.
BigNev Posted June 16 Posted June 16 (edited) Hi Joel! I have the same model same year - but it is not a guarantee they will be the same - Lee should be able to confirm this. I have only done the front, and I used Apec discs DSK2829, 296mm diameter, Toyota 43512 28190, and Apec pads PAD1580, Toyota 04465 28520, and have found them absolutely sound. They are certainly a heavy piece of kit! From those numbers - but only if Lee confirms the originals for yours are those - you can cross reference to other manufacturers. Edited June 16 by BigNev
Picasso Posted June 16 Posted June 16 Neville is correct front pads 0446528520. Front discs. 4351228190 APEC is a very good brand 1
Joel7513 Posted Tuesday at 06:46 AM Author Posted Tuesday at 06:46 AM Thank you both. will have a look at where to purchase.
BigNev Posted Tuesday at 06:51 AM Posted Tuesday at 06:51 AM No worries! Did you need help with the numbers for the rear too? (I don't have myself- yet!) I'm lucky that my local autofactors do have access to the Toyota parts system.
Picasso Posted Tuesday at 03:33 PM Posted Tuesday at 03:33 PM I will put the no.s on for the rear soon
Picasso Posted Tuesday at 03:43 PM Posted Tuesday at 03:43 PM ok rear pads oe no. 0446658010 cross to apec PAD1334 blueprint ADT342147 brembo P 83 047 rear discs oe no. 4243158020 cross to blueprint ADT343236 brembo 08.D712.11 if you need any more no.s or part diagrams pm me i can cross reference oe no.s to aftermarket parts just bear with me i like doing this .
Picasso Posted Tuesday at 03:50 PM Posted Tuesday at 03:50 PM may aswell add the rear handbrake shoes oe no. 4655028020 crosses to herth and buss J3512004 brembo S 83 542 what i will do when i get time is do a spreadsheet of all part no.s and cross reference no.s for all the service parts for each alphard / vellfire this will make it lot easier for all the members and see if there is a way we can add it to the forum . 1
