Hi all
I’m two years into Vellfire ownership and have been advised I need new disks and pads due to wear (I was expecting this)
I cannot locate the spares on the normal sites like eurospares etc. Not sure if this is because I have personalised plates put on or whether it’s because it’s an import.
could anyone help with part numbers or the like for disks and pads all round please?
2010 3.5V6.
thanks in advance.
Hi Joel!
I have the same model same year - but it is not a guarantee they will be the same - Lee should be able to confirm this.
I have only done the front, and I used Apec discs DSK2829, 296mm diameter, Toyota 43512 28190, and Apec pads PAD1580, Toyota 04465 28520, and have found them absolutely sound.
They are certainly a heavy piece of kit!
From those numbers - but only if Lee confirms the originals for yours are those - you can cross reference to other manufacturers.
Edited by BigNev
Neville is correct front pads 0446528520.    Front discs.  4351228190    APEC is a very good brand
No worries!
Did you need help with the numbers for the rear too? (I don't have myself- yet!)
I'm lucky that my local autofactors do have access to the Toyota parts system.
ok rear pads
oe no. 0446658010  cross to apec PAD1334  blueprint  ADT342147   brembo  P 83 047
rear discs
oe no. 4243158020    cross to  blueprint  ADT343236  brembo  08.D712.11
if you need any more no.s or part diagrams pm me i can cross reference oe no.s to aftermarket parts just bear with me i like doing this .
may aswell add the rear handbrake shoes
oe no.  4655028020   crosses to   herth and buss  J3512004   brembo  S 83 542
what i will do when i get time is do a spreadsheet of all part no.s and cross reference no.s for all the service parts for each alphard / vellfire this will make it lot easier for all the members and see if there is a way we can add it to the forum .
  • Thanks 1
