Is it easy enough to change the bulbs on a 2011 Vellfire? The light under the main headlights are flickering on both sides.
Yep, doddle, done all on mine, side lights, headlights, and high beam, piece of cake.
Cheers! I'll have a go today.
Just been informed it's led side lights. Would any garage be able to fix these?
Edited by Gram
That shouldn't be a complication, they were replacement led's on mine, W5W type, local shop had them.
These are the ones on ours!
Brilliant. I've ordered from Amazon and hopefully I've found a garage to change. Thanks for your help!
They are quite brilliantly bright 🤣
But honestly, you don't need a garage for that job, not if you're remotely practically inclined!
You can find full maintenance manual, including instructions for bulbs online.
I won't post link, to avoid breaking forum rules, but if you do s Google search for
English Repair Manual (09/2012-->12/2014) (RM2443)
You will see a site that contains the manual, you will also find wiring diagrams.
Thanks again!
