AFS question
Hi all,
I’m not sure if my AFS is working or not.
I’m driving a 2006 3.0L MZ Alphard.
I sat parked up tonight with the. Headlights on and toggled the AFS switch on and off with a pause of about 10 seconds in between and noticed no change in the light pattern. I assume there should be a bit of light movement when changed, is that correct?
Does it need to be working for the MOT? if so I may have to get it fixed before the test.
Thanks in advance
Switch off ignition, then start engine.
Afs wont adjust whilst stationary, except during start up when it calibrates itself.
Its most noticeable when turning corners, you should see the light pattern move to the side.
The manual I found on here, and had printed, says it this way:
AFS (Adaptive Front Lighting System) improves visibility at intersections and on curves by automatically adjusting the direction of light axis of the headlights according to vehicle speed and the degree of the tyre angle that are controlled by steering input.
Operates at speeds of 10km/h (6mph) or higher.
I had the engine running, I never notice anything when driving around bends.
Those words are not mine, I typed them exactly as they are in the Toyota manual.
I don't notice it either mate!
One of those gimmicky things, there might be some very tiny benefit sometimes.........
Edited by BigNev
It seems the AFS is actually working.
I never take notice when the lights come on but last night when I started the car I made a point of looking where the light points to when switched on and I could see the beam moving up and down as it seemed to calibrate itself.
When driving along a country lane I tried to see if any movement laterally when going around a bend and I think there was a little, very subtle movement I think so it does seem to be working after all.
I did find something online suggesting that in the first 15 mins of starting the engine whilst stationary one could as a test turn the steering wheel side to side and should see sideways movement but I haven’t done this but may do to satisfy my curiosity.
AFS on my 2007 3L MS spec definitely works. Country roads highlight it best. Turning round a corner, then letting go of the wheel to let it correct itself will show it clearly. You can see the beam of light actually moving back to a straight position.
I also noticed that when you turn on the lights, they appear dim, then brighten within a few seconds. I always thought that was just the type of bulb warming up yknow? But it may well be the AFS system doing a self-check. I'll have to stand outside the vehicle and get my partner to turn them on while I watch. She can't even notice AFS working on the country roads, but to me it's clear they are indeed operating normally!
Hi @ TheRizzler!
You're correct on the bulbs, they strike up and then gain full brightness over a few seconds.
On the up / down movement, that's the auto levelling system in action.
I feel a need to go out for a drive one evening to see if I can detect my AFS in operation 😀
