Just before I attempt to fix it... Does anyone know a supplier for the series 30 built in phone holder? One of the spring mounts as snapped off mine
If it's a factory fitted unit have you tried amayama.com? Postage takes a while but if you put in your vehicle details it will tell you which part numbers you need.
Thanks... Didn't end up being to go that far, I used a very small screw and replaced the tiny bit of plastic with that and working well again
