Ah10 radiator for 56 plate
Hi Everyone... struggling to locate the right rad for my Ah10. Found this on radiator and need to know if it is a relevent part number. Any info would be great. Thanks Dean.M
Edited by Mack
I think 122070-0422 is the Denso part number rather than the Toyota part number (which are usually 5+5 digits not 6+4; the D on the marking is Denso's logo). Looking at Amayama for an ANH10 (but you should enter your chassis number to confirm):
https://www.amayama.com/en/genuine-catalogs/epc/toyota-japan/alphard/ANH10W/36857/engine/1603
it looks to be Toyota part 16041-28610 for the radiator itself in a 2006. If you have a different year, the 3.5 or the hybrid then it will be different - search Amayama with your chassis number.
Edited by Ptarmigan
One thing though, that appears to be a picture of the fan shroud (the plastic around the fan blades) not the radiator itself, which is made of aluminium. So if you need the aluminum part I wouldn't go searching for the Denso part as that'll get you the fan plastic. If you need the fan motor or blades those will be different parts - the Amayama page has them.
