Tailgate seal
Hi again!,
Not sure if this is referred to as the tailgate seal but anyway it's coming away and perishing further along. Can anyone recommend the replacement seal I need for this?. (AH10 2.4).And whether it's an easy job!
These photos may make it clearer.
DaveoIMG_7244.HEIC.pdfIMG_7243.HEIC.pdf
Is this the part, the 'weatherstrip, back door'? This is from amayama.com for my 2005 facelift model. If so the part number is 67881-58010.
A quick look on ebay would suggest that it's cheaper to get it from Japan, but I only spent 5mins looking.
Make sure you put the correct model number into sites like amayama.com.
Thanks Gamith, I don’t think it is that part but will use the diagram to try and identify it. It looks like it slots in the top and just runs the width of the van bending round at each end.
I am wondering whether yours is a post 04.2008 model as I can't locate anything similar to mine on Amayama. but then I'm not entirely sure where I am supposed to be looking - this is on the roof above the rear door isn't it?
Wait - could it be this one?: image.png
Edited by Gamith
to add a picture of what might be the item
Ah, that looks more like it, 76872. I looked again today, the seal is in the boot door itself or perhaps the spoiler attached to the door.
I’m pretty sure my model is AH10/2008
To make sure look at the 'plate' attached to the the B pillar - passenger side.
With 2008, as with my 2005, the models changed halfway through the year though I think, someone will correct me I'm sure, rather than a facelift the model changed to the 20.
Either way using the top line / Model information on Amayama.com will get you the right information. I found out the manufacture date from a CarVX report.
Ah perfect, I will check to confirm for sure, though I’m confident my van was the early part of 2008 so AH10, I remember also the crossover part way through the year.
easy to
Easy easy to check. Does your rear wiper sit under the roof spoiler? 20 series.
Does it attach to the tailgate below the glass? 10 series.
