Hand brake warning light
Hello there!
Have you checked your brake fluid level?
The warning light doubles up for that.
Cheers, Nev
Thanks for the reply.I found a old autologic diagnostic tool i forgot i had traced fault to feft hand rear abs sensor must have got damaged with all the hammering doing the rear bushes.Do you happen to know if I need remove bearing to fit new one.Regards Geo.
