E10 fuel upgrades
I have just bought an 06 Alphard Hybrid what will I have to to the fuel system to make it compatible with E10 fuel which contains ethanol.
There are lots of threads that discuss the E10 fuel issue.
I respectfully suggest you search this site to help you decide whether you need to do anything, and, if so, what.
Chris if it's any help, I have a 2003 alphard and have been using E10 fuel for 1k miles now and all OK so far. This without doing anything to the van. Fingers crossed it stays that way :) Ian y
So this new fuel roll out on the 2002 - 2008 3L models will actually burn your piston rings and cause clogs.  This came from a mechanic who actually contacted Toyota Japan and asked them directly. The only option for us is to use super unleaded.
Difficult to argue with this !
I need to reread all that NREL info I published before as one of the engines tested was the 1MZ FE engine with no degradation at all.
Yeah I agree. But i'd rather air on the side of caution rather than an expensive bill for redoing the piston and seals.
