Front lower control arm replacement
has anyone done this and have any pointers how to get to the bolt hiding behind the engine/transmission mount?
thanks!
MonsterS, thabks! But the link doesn’t seem to work.
I’ve managed to sort it eventually, that bloody mount makes a simple job silly complicated but it’s down and hopefully won’t have to do it again for a while 😂
1 hour ago, MonsterS said:
that should be downloadable.
It is !
But there is nothing in it.
Is there anything there if you open it ?
Just had mine done by a local garage, he said he had to remove the engine mount to get at the bolt
