Undersealing Gen 2?
When I imported my car I asked to have it undersealed by the guy doing the IVA, fog and speedo conversion. He didn’t do it, claiming that cars younger than 10 years don’t need it. I wasn’t convinced by this at the time, but I’ve just asked someone else if they would do it and they said that Japan imports are usually in good condition when they get here so they don’t need it.
I thought undersealing was a standard practice for imports. Has something changed in the last 10 years that makes it not worth it?
it’s not the condition of the car now I’m worried about, it’s the condition it’ll be in after a few months of living near the coast and a winter’s worth of salty roads.
I guess the undersealing issue depends on
How long you intend to keep the vehicle, and
Whether you use it during the winter when the roads are salted.
What cost peace of mind, although even undersealing doesn't provide any guarantee.
I live near the coast and experience very salty raining during the winter south westerlies.
 3 spray cans of halfords underseal gel allowed me to do it myself with the help of a jack and two axle stands and yes the sea is 120 yards away from our back garden😁
Nothing has changed, it needs to keep it in good shape. We do it on all ours in either clear or black (customers choice) on all cars.
He is probably referring to the rubbish that comes over that is rusty and 'needs' underseal to hide the rust!
Thanks all, that’s what I thought. Now I need to find someone in the North East who will do it. Not sure I’m up to doing it myself, that kind of messy job is guaranteed to drive me up the wall.
If you care about the car it's an absolute essential. Japan does not salt their roads (they use antifreeze spray) and consequently they don't need to underseal their cars.
From chatting to some other people I’ve found out that Toyota improved their galvanising process sometime before 2010, so it’s not as bad as it was, however they still don’t protect from corrosion in the same way that, say, Volkswagen do.
Anyone have any thoughts on Lanoguard? That looks like the level I can handle doing myself, even if I have to do it once or twice a year. I’ve heard everything from “I’m a farmer and it’s the only thing I trust” right down to “snake oil, absolute con”.
This is brilliant, thanks Chris.
So I had a go at applying Lanoguard today. Jacked up the front on to a pair of axle stands - bricks under the wheels as backup - and I just had enough room underneath to slide around on a piece of cardboard.
It was easier than I thought. Spent about 45 minutes applying the grease to bolts, weld seams, and especially the box ends, which were starting to corrode but not flaking yet. Then another 30 minutes spraying the underside, and finally another 20 minutes using the long nozzle to get in all the holes.
Hopefully this stuff is as good as the hype. The kit I bought was about £90 and I used just over half. You’re supposed to apply it every year or so. Waxoyl works out cheaper if you do it yourself but this wasn’t very messy, and it’s much cheaper than any quotes I had to have undersealing done for me. I do smell like a sheep now though
  • 3 years later...
When I purchased my Alphard 20 series, the supplier had it undearsealed with “Body Shuz.” I have had the vehicle for just over 14 months and am tempted to get it undersealed again around September ready for next winter. I had never heard of this product before, only Lanoguard andWaxoyl. Two questions really:
  1. Which product would be the recommended one to use.
  2. Am I timing this right, how often would underselling need to be done.
    Thanks.
Schutz is a generic name for a bitumen based under body coating. It's similar to the kind of tar used on flat roofing. It's derived from crude oil and contains a solvent which makes it flow (eg white spirit). Once applied the solvent evaporates leaving a tarry layer. Unlike paint it has some flex in it, so it can stay stuck to a surface which changes shape through eg thermal expansion, where a rigid paint might flake off. When applied it has the consistency of whipped cream, although you can thin it for spraying.
Lanoguard is perhaps the most heavily advertised (ie expensive) of various lanolin based products, including Fluid Film and various DIY mixes. Lanolin is a wax that's a waste product of the wool industry - basically Australian sheep farmers had this wax left over from wool processing and wondered what they could do with it, and found out it had similar flexibility properties to the bitumen above. Again it's thinned for application and the solvent evaporates leaving a waxy layer behind.
I've used both, and while I'm no expert I'd say the lanolin wax often comes out as a thinner layer than the schutz, but on the other side lanolin has more compatibility with rubbers and plastics where an oil based product may cause degradation. So schutz is more for bodywork, where lanolin is safe for hoses, gaiters, suspension bushes etc. But the lanolin layer being thinner is more susceptible to stone chips etc so needs redoing regularly, while the schutz is more of a one time application.
As your car already has schutz I might be looking to top up the schutz on the body and perhaps use lanolin on the mechanical parts. I don't really have a recommendation on brand - I did a car in black Waxoyl schutz underneath and clear Waxoyl wax (which is more like paraffin wax) on the mechanicals and in the cavities and without further treatment it lasted 7 years before signs of rust started to come. More recently I've been using Fluid Film - too early to say but it looks to have stopped the rust. What I did do on my Waxoyl job was spray surfaces with penetrating oil first, to displace any trapped water and provide an oily surface for the wax to key onto - that seemed to work quite well.
One downside of the schutz though - as it never fully sets, if you later work on the car you do tend to get black marks on your hands, clothes, etc. But that's just evidence it's doing its job.
Edited by Ptarmigan
Hello mate
If it was done properly with body schutz 14 months ago, you probably do not need to fully redo it yet. The main thing with bitumen schutz is it lasts quite well until it gets chipped or starts lifting at edges, and that is when it can actually make things worse by trapping moisture behind it. So I would not just blindly coat over everything again without a good look first.
What I would do around September is a check and touch up rather than a full respray:
  • Get it up in the air and inspect the usual spots on Gen 2: rear subframe, sills and jacking points, seams at the ends of box sections, behind plastic arch liners, and any areas that take stone impact.
  • If the schutz is intact and well bonded, leave it alone and just repair chips and thin areas. If any sections are bubbling or lifting, that wants scraping back to sound coating, treat any surface rust, then recoat.
  • Use a lanolin product (Lanoguard, Fluid Film etc) on mechanical bits and awkward areas: brake pipe runs, fasteners, suspension arms, around tank straps, and anywhere near rubbers and bushes. Lanolin is much kinder around plastics and rubbers and is good at creeping into seams, but it does wash off over time so plan on redoing it more often (usually annually).
    Timing wise, early autumn is about right, but only if the underside is dry and reasonably clean. Ideally do it after a decent dry spell, wash underneath, let it dry fully, then apply. If you apply onto damp grime you are just sealing in the problem. Trade off wise: schutz is tougher and more stone chip resistant but can hide corrosion if it lifts; lanolin is safer and easier to reapply but needs regular top ups and can attract dirt. If you can, post a couple of underside photos (rear subframe area and sills/jacking points) and people can usually tell you quickly whether it looks like a top up job or whether any prep is needed.
    Let us know how you get on.😉
16 minutes ago, Matchbox Toyota said:
Hello mate
Thanks for the detailed reply. I have made a note of all your recommendations and check the underside in the early autumn. Very grateful.
