I have just bought a 2008 ALphard 3litre and have calculated the fuel consumption to be 15.5 mpg.
Is there any advise as to what could be causing the low reading .  I took to a garage who changed the spark plugs and tested the emissions and  which are in the acceptable ranges.
Ian C
full service?
Did you put a full tank of premium fuel in instead of standard?
Are you town driving?
I get around town between 15 - 20 mpg depending on how i drive.
on motorways i get between 20 - 30 mpg.
Make sure the gear lever is in D and not 4 otherwise the MPG will plummit.
Thanks for the replies.  I have been using Regular fuel and  definitely in D not 4  gear setting.     I have had it in to a garage who have put in new spark plugs and done a road test attached to the ECU which has reported that the consumption is averaging 24.8 mpg????  The other tests done on the engine have readings in the spec ranges , so I am told.  No issues have been flagged from all this testing.
Worth bunging in a full tank of premium and going on a nice long road trip.
I did that and noticed my fuel consumption went up. since then i put a full tank of premium in every 20 -30 fill ups.
