Hiya has anyone found a radio that I can replace the origional one with that actually fits in the space ? I am running the origional one with a band width expander but it's pretty useless. I have a 2008 Alphard V
There are lot's on Ali express. If you send them a picture with an image on the back of all the wires and plug's they can match it like for like. :)
Thank you for that Are they reasonably easy to remove ?
I have found Audio Tech Direct very helpful. Tell them what you have and what you want and they will advise.
sales@audiotechdirect.com
https://audiotechdirect.com/
If you can do basic auto electrics, it's doable.
Easy to remove - Ebay has videos. I have messed with electronics for 50 years and I didn't find installing the new one too easy. I installed this https://www.aliexpress.com/item/1005002717835170.html?spm=a2g0o.order_detail.order_detail_item.7.541ef19cnMpIP7
Radio, music player, gps, emails, phone interface - everything you could ever need. In actual fact it's an android touch screen tablet. You might find there is a straight radio replacement if that's all you want.
Many thanks for that will check it out 👍
It depends on what you want the new one to do, alot of people seem to be going for android units but I have seen on other forums that the cheap ones tend to go wrong. I fitted a Pioneer AVIC-Z620BT it does everything I need it to do, i.e. sat nav, bluetooth, mirroring, 2 camera inputs, only had to get a loom for the steering wheel controls and new cameras for the front & rear, the oem are 6volt.
