hi I've been trying to get the car started for the past week I've tried everything to get it going its had a new ignition switch tested the battery and starter all seem fine but when you put the key in the ignition you get power until you try to crank the engine then i just get a flash of the lights on the dash and that is it no crank or nothing,
i have also tried starting the car in neutral but that doesn't work either.
if anyone could shine some light on this it would be very much appreciated as i am pulling my hair out with it now
thanks.
  • Replies 53
  • Views 11.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • start relay fuse is located behind passenger glove box I have attached drawings from lookup system circled in red hope this helps location is 2
  • Thank you everyone for your help, the love bus is up and running again. It all down to a relay in the passenger footwell
  • Fuse is 7.5A.
Posted Images
If the dash lights are going off when you try to start it then there is a major voltage drop, if your battery is more than 5yrs old then it could have a faulty cell, check all terminals are clean & tight on the battery, starter and the solenoid, if you can start it with a battery off another car then you know that yours is kaput
ive have a new batter put on this week and the starter motor gas been off and tested, that was fine
I have tried to get a diagnostic done but when they plugged it in the ODB wouldn't power the reader
Check all fuses sounds like a fuse has blown have you shorted the battery when putting new battery on by putting leads on wrong way round
Edited by Picasso
Spelling
Could very well be a bad earth too . Make sure all the connections to the bodywork are clean and tight
I've not checked the to see if the earths are tight to be honest I've noticed there is about 4 or 5 of them though
Hi. I've been told that Jap vehicles have to have a different diagnostics plug in to ours. They can be bought on the internet, I believe?
John Harrison. Wirral.
Other owners may be able to confirm this?
JBH.
Thank you for that I will have look on Amazon for one
ANCEL JP700 JOBD OBD2 Japanese Car Scanner, JDM Automotive Code Reader Check Engine Light OBDII Diagnostic Scan Tool fit for Toyota Nissan Honda Mazda Subaru Vehicle Diagnosis https://amzn.eu/d/2kEDJcg
Is this the correct reader ?
Could anyone tell me where to find the starter relay please, is it the main box under the bonnet or the one next to the battery
Yep. That's the one I have.
While this is a good thing to have, this is only of relevance if the check engine light is illuminated while the engine is on. It might not tell you why it doesn't crank.
The radio and everything powers up when i put the key in but as soon as try and start the car nothing happens
This what's happening when I try and start the car
Good video. It shows that the "doors open" light remains on when you attempt to crank. That probably means your battery is fine.
The OBD reader not being powered could be the OBD fuse gone. That's fuse 10 in the box by the driver's seat.
Thnk you will have a check
14 minutes ago, MonsterS said:
Could be the imobiliser chip, you said you had a new Ignition barrell fitted. Was it programmed afterwards to match your master key?
It was a new ignition switch I've had put on will it still need coding ?
the barrel seems fine
On 8/6/2023 at 7:53 AM, Picasso said:
Could you tell me where to locate this fuse on the car please I can't find it
4 minutes ago, Rojie said:
I only have one behind the dash on the driver's side
 Your model is the Gen 1, pre-face lift version.
Mine is the post face lift version.
The JPNZ Owners Handbook definitely states fuse 10 in the fuse box by the drivers seat.
Does the fuse box you have have 10 fuses, no more ?
My model is an MZ G Edition; so your seats are probably not the same as mine.
I'm sorry I cannot help further.
