Hi does anyone know where i can get a wiring diagram for automatic door toyota alphard velfire 2004
Hi Steven,  I have full Japanese wiring diagrams for 2002 - 2008 ANH1# and MNH1# and I have translated much of it to English.  I have mainly concentrated on the A/C and engine and  I havent yet translated the body and lighting but I could do those sections for you if it can be narrowed down a bit.   (The full set is about 400 pages long!!)
Ive attached the index to the wiring schematic pages.  Can you identify those you need?   I would also need to know the frame code and year
Cheers David
Diagram-3-1.pdf
Edited by FrenchDJ
Cheers David
@FrenchDJ Hi David. How have you gone about translating the wiring diagrams? Could it be something that could be done piecemeal by various people to speed it the task?
I have the Totota official Japanese electrical wiring diagrams for the Alphard G and V 2002-2005 and on until 2008.   It is bound into a book and I am scanning it page by page and translating it to produce a graphic file for each page.   I dont want to break up the book as it cost a lot to source and have shipped back to the UK.  As my vehicle is 2003 I have been concentrating on the sections for the 2002-2005 options.
If someone has a problem and needs the diagrams and I have already translated the relevent pages, I can email them.    If I havent scanned the required pages yet then I can do it for them and build up the set that way.
I dont currently have any plan to do the entire book as a "project" without an express requirement.   I have translated about 100 of the 481 pages so far.
Ive attached a sample page from the A/C section
David
Hi do you have a diagram for hazzards please indicators work but no hazzards
Thank you managed to sort had a plug loose in flasher ecu .
  • 5 months later...
Cheers David
is there a wiring diagram for the Alphard pfl 2004 head unit
Don't suppose you have got the the Diagram for a engine temperature sensor?
I am bamboozled by why I have nothing on the gauge but appear to have power in the right places and no other things playing up...
  • 5 months later...
Cheers David
Hi French, Can i have autolight wiring diagram for MNH10, my autolight not working
Hi Sunesh,
I expect I can supply this but I need a bit more info to identify the correct diagrams.  What exactly is the autolight...what does it do and what systems does it interact with.    eg it is controlled by the engine management system in any way, does it link to the transmission.  Ive not heard the expression before.
David
I believe this refers to the automatic turn on and turn off of the lighting system.
The sensor is in the middle of the upper dash panel.
By lighting system do you mean the internal cabin lights, and by automatic do you mean when you enter and leave the vehicle?
On 7/4/2025 at 6:46 AM, FrenchDJ said:
If you mean the automatic activation of the headlights at night ive got the diagrams at https://photos.app.goo.gl/ujqqpTscNXGXqnkL8
I hope it helps
David
Dear French David,Yes this what i need to troubleshoot my auto-light.
Thank you for your help and really appreciate it.
