Wiring diagram
Good morning. Wondering if anyone can help with a wiring diagram for the air conditioning for a 2006 3ltr Alphard. I have the diagrams for the fuses and these have been checked, but need to check the wiring as there is no power going to the compressor. Thanks for your help in this. Cheers Barry
On 3/16/2024 at 5:43 AM, FrenchDJ said:
Hi Steven,  I have full Japanese wiring diagrams for 2002 - 2008 ANH1# and MNH1# and I have translated much of it to English.  I have mainly concentrated on the A/C and engine and  I havent yet translated the body and lighting but I could do those sections for you if it can be narrowed down a bit.   (The full set is about 400 pages long!!)
Ive attached the index to the wiring schematic pages.  Can you identify those you need?   I would also need to know the frame code and year
Cheers David
Diagram-3-1.pdf
Dear French,
Can i have below wiring diagram
Body Related
Power assist door (sliding door/LH) 3-76
Power assist door (sliding door/RH) 3-80
Power assist door (back door) 3-84
Easy closer (sliding door/LH/RH) 3-88
Easy closer (backdoor) 3-90
Cheers David
Diagram-3-1.pdf
Hi Sunesh,
I am away for a couple of days. I will sort it out at the weekend
David
Hi Sunesh,
David
Sure, no problem. take your own time.
Thanks! I'm going to tackle fixing my power sliding door next. I actually managed to successfully fix and wire the rear power boot before this, so I'm ready for the next challenge
Hi Sunesh,
Here is the link to the diagrams 3-76 to 3-91 covering the door that you needed.
https://photos.app.goo.gl/PTTwPf9Z7ojhUdNRA
This contains 14 png image files. You need a big screen to be able to zoom in on the details. The images include data about the wires and connectors.
Some of the vertical text may not have translated - if you have particular need for something that has not scanned well enough or has missed translation then let me know
I think some of the diagrams sent in by others earlier in this chat may be for models 2008 onwards.
Sorry it took so long
David
Edited by FrenchDJ
