Fitting a auto folding mirror module
Toyota alphard 2003 3.0 Trying to fit a automatic side mirror folding module stuck on wich wires conect to mirror switch should cut 2 and wire plus closing wire and plus opening wire to the unit
Edited by Tony123
Added picture
Hello Tony,
I did fit one identical to my 2012 vellfire couple of days back. Do you have a wiring diagram for you car?
I’d like to fit one to my 2010 Vellfire. Do you happen to have a link to the one you bought and was it easy enough to fit?
Thanks.
Thanks.
Hi Mitch, this is the one: https://www.ebay.co.uk/itm/166463511541?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=sODE7-S-RAO&sssrc=4429486&ssuid=4VUOd8_gQG6&var=&widget_ver=artemis&media=COPY
Mine has arrived now, so if anyone has any wiring info it’d be appreciated.
  • 9 months later...
Same here - that looks to be the same one I have tried to fit (several times), but I don't think I have the right connections as it doesn't want to work 😞 My mirrors will go in and out on the press of the button, but not on engine / ACC power on.
