Hi, Any one know or have wiring diagram for auto light.
My Alphard MNH10 auto light not working.
I had change another switch but still no respond for auto light.
I try clean the sensor head but still same.
Anyone know where is the relay or module that control auto light?
Good morning Sunesh - I am afraid I am not sure what you mean by 'auto light' is this an internal or external light?
What makes it automatic?
The only item I can think of is when it gets dark the headlights will come on, is that what you mean?
Do you mean the light by the shifter, or perhaps the one in the dash panel ?
Yes, i mean the headlight. The light will automatically ON ones get dark.
The headlight sir, the light shall ON ones get dark.
I had change the switch on steering but nothing happens, therefor looking for wiring manual to see any relay for this unit or not.
On 10/20/2024 at 3:25 AM, Picasso said:
Might be a daft question have you got the light stalk turned to auto
Headlight sir.
So Sunesh means the light stalk.
In Auto, if the engine is stopped the lights turn off.
If the ignition is off the lights will not work on automatic.
Check you do not have the sensor in the middle of the dash covered.
Do not clean the sensor with glass cleaner.
Do all the other functions on that light work correctly ?
Yes, i has try it ones enjine running infact tested on night while running
All function light all ok
I just clean the sensor with wet and dry cloth.
On 10/25/2024 at 4:26 AM, Gamith said:
I have found the attached which may be of help (though there is no indication of years covered).
Unable to locate TAIL relay. Main light relay on front fues box, however TAIL relay unable to trace.
