sby148 Posted November 1, 2024 Posted November 1, 2024 Hello all members I'm new member here and I understand you can help me to find what's wrong with my Alphard. The car done already 123k miles. After driving the car around 20-30 minutes it's start shaking specially when I'm driving up hill it's can be very bad shaking. The shaking is only for few seconds and than the car drives okay,however it's can come back after few minutes again. The car was by 2 mechanic that have a lot of experience with Alphard but unforetunately they couldn't find the problem. The car doesn't show any warning light and on diagnostic it's doesn't show any fault codes. The Registration number is GX53ZFV. If you need more details let me know. Please try to help me because I'm planing a long drive with it and I can't do it till problem is solved. Yours Sincerely Simon 1
starider Posted November 2, 2024 Posted November 2, 2024 Hi, It sounds like it could be a front wheel bearing/CV joint needs replacing. It could be an intermittant misfire from the engine. a loose wheel/ damaged tyre. It certainly suggests something around the wheel/transmission/drive shaft area. 1
ThuMentaliss Posted November 2, 2024 Posted November 2, 2024 Does the noise increase /decrease when going around a bend? is the noise associated with a vibration?
sby148 Posted November 2, 2024 Author Posted November 2, 2024 It doesn't make any different while driving in bend. Only on uphill it's stronger.
Henry freeman Posted November 2, 2024 Posted November 2, 2024 if happens under load sounds like inner cv joint ,had same problem .when driven just a few miles was ok on longer trips the vibration got worst when i let off foot pedel it stopped ,drivers side
Antfryer Posted February 5 Posted February 5 Hi i had the same problem, the garage i yous said it was the drive shafts. I got 2 drive shafts of the internet fitted them no more vibration. I got Drive shafts from J&R trading (UK)Ltd. 1 1
andyc Posted Thursday at 01:51 PM Posted Thursday at 01:51 PM I've got a similar problem but I've noticed J&R Trading get terrible reviews. Have the ones your bought been ok ? I got a quote for £1000 each from Toyota!
Antfryer Posted Thursday at 02:25 PM Posted Thursday at 02:25 PM I have'd no problem since fitting, J &R Trading delivered parts the next day by DHL courier.
andyc Posted Thursday at 02:29 PM Posted Thursday at 02:29 PM Thanks for the update. My Alphard does not judder until it's done a few miles (warmed up) then the judder starts when accelerating especially up hill (under load)
Antfryer Posted Thursday at 02:35 PM Posted Thursday at 02:35 PM Yes, same symptoms as mine, the longer you leave it the worse it gets.
Alphard Club Posted Friday at 03:27 AM Posted Friday at 03:27 AM have you checked the transmission oil? it may be low and not enough getting round the torque converter when hot. This will cause it to shake going up hill. 1
andyc Posted Friday at 07:49 AM Posted Friday at 07:49 AM I've just had it changed at Toyota this week. I thought the same it might be related to old oil. Unfortunately it's made no difference at all.
Alphard Club Posted Friday at 12:53 PM Posted Friday at 12:53 PM 5 hours ago, andyc said: I've just had it changed at Toyota this week. I thought the same it might be related to old oil. Unfortunately it's made no difference at all. Sorry Andy my reply was for the original poster as his shakes and not judders. Lack of Transmission oil will make the car shake I did respond to your thread earlier.
