Hi
I wonder if someone can help me with an answer regarding warning lights.
If a 2008 Vellfire has a 4 X 4 icon on the instrument/display, is that on every Alphard/Vellfire?
So when it actually is a 4 X 4 it lights up, & otherwise does not if it's only two wheel drive.
By the way this forum is a great, & useful source of information.
On 11/3/2024 at 1:40 PM, Alphard2024 said:
Hi
post a pic of where it is on the dash display and i will look at mine (2 wheel drive) this is a dificault thing to answer because you would only see it if it was lit up.
I suspect that every generation of dash will have the same cutouts for any function, whether there is a bulb behind it, let alone the actual functionality is another matter. If you're not sure about having 4WD take a look at your rear suspension - can you see a differential and driveshafts?
